Using low compression pistons..
Old May 19, 2003 | 08:47 PM
crexer's Avatar
Default Using low compression pistons..
allright may be a noob question but here goes...
im building a b16a right now and plan on going turbo. I got JE low compression pistons and after I get the motor built im going to be broke as hell and would need to save for a while longer to get a turbo...If i go ahead and swap the motor in would there be a really big difference in power being low compression without the turbo? and would it be allright to do this...? Please let me know your expertese opinions
Old May 19, 2003 | 08:49 PM
untitled's Avatar
Default Re: Using low compression pistons.. (crexer)
just leave em in until you boost. it would be just too big of a hassle in my opnion to rip it down two times just to change pistons.
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crexer &raquo;</TD></TR><TR><TD CLASS="quote">allright may be a noob question but here goes...
Yeah power will be down a little due to the lower compression but not to much(depending on what compression you went with).
Yeah you can drive it like that with no problems
Old May 20, 2003 | 12:34 AM
Pritos's Avatar
New User
Default Re: Using low compression pistons.. (b16ahybrid)
I've 8:1 on my sohc z6. low end is a dog but once the turbo spools around 3700 its partay time.
Old May 22, 2003 | 07:27 PM
crexer's Avatar
cool; anyone else have any input?
Old May 22, 2003 | 09:17 PM
Type-GS-R-Turbo's Avatar
I'm running low compression without a turbo on my GS-R motor right now. It's a little rough at first but it's better for the motor. It's good to run it without the turbo for the first 1000 miles or so to ensure that the rings seat properly. Once you get used to it, it's not that bad.
trav39562
Mar 31, 2009 04:39 PM
trueno808
13
Oct 15, 2006 09:07 AM
94gsr18kid
10
Jan 25, 2005 05:35 PM
94gsr18kid
Jan 25, 2005 09:02 AM
