Dyno results
Old Jul 26, 2003 | 09:35 AM
Maxime's Avatar
Default Dyno results
7psi on every runs
Stock B16A2
GSR Cams
RC550
Walbro 255lph
SMC+
Greddy manifold and turbo (18G)
Custom 2.5" downpipe
Custom 3" exhaust
Base run:
188.2 hp & 149.9 ft-lbs
The air/fuel is off the scale. WAY too rich.
After 5 runs of tuning with the SMC+ we managed
238.3 hp & 160.6 ft-lbs
I still need a lots of tuning. For some reasons the SMC+ was 1000rpm off. Everytime we tried to lean at lets say 6k-7k. It was leaner at 5k-6k on the wideband.
I am still very happy with the numbers. Next step? A better fuel management and more tuning.
Modified by Maxime at 11:41 AM 7/26/2003
Old Jul 26, 2003 | 11:07 AM
ProEater's Avatar
Default Re: Dyno results (Maxime)
gives me hope for my b16a2!
Old Jul 26, 2003 | 11:10 AM
hatchback19's Avatar
Good numbers, good torque for the b16. How do you like the SMC for how much it costs?
Old Jul 26, 2003 | 11:12 AM
Mr. Softee's Avatar
Default Re: (hatchback19)
funky graph but good power @ 8psi.
Old Jul 26, 2003 | 11:14 AM
ProEater's Avatar
Default Re: (94goldjungsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94goldjungsr &raquo;</TD></TR><TR><TD CLASS="quote">funky graph but good power @ 8psi. </TD></TR></TABLE>
he said it was at 7psi......
Old Jul 26, 2003 | 11:26 AM
Maxime's Avatar
Default Re: (ProEater)
I need more tuning. The car was too rich in the 3.5K-5k range. But I decided it was better to tune the upper rpm. I only had 5 runs to tune. Next step is a hondata and some more tuning.
Old Jul 26, 2003 | 11:27 AM
civicguy's Avatar
so that mean that you can use 550cc injectors on the smc or safc,i bet you migh be able to run more than 10 psi without a cell,i will say 15 psi,i think that as long as you keep your map from seen3.0 volts you can keep increasing boost,i have go up to 14psi without the cell and not a single problem,
Old Jul 26, 2003 | 11:48 AM
hawjdude's Avatar
Default Re: (civicguy)
nice numbers.
Old Jul 26, 2003 | 12:04 PM
Civic TSI's Avatar
Default Re: (hawjdude)
Good job Max
Old Jul 26, 2003 | 12:20 PM
ATgrills.com's Avatar
Default Re: (Civic TSI)
where did you get it tunned?? L-sport or Zekes????
Tyler
Old Jul 26, 2003 | 12:37 PM
Maxime's Avatar
Default Re: (ATgrills.com)
I tuned it myself with a friend. I dynoed the car at Zeke's.
Old Jul 26, 2003 | 12:55 PM
Default Re: (Maxime)
why not L-sport?? they have a better dyno and a more precise wide band o2 sensor!
Old Jul 26, 2003 | 01:12 PM
SiRkid's Avatar
nice!
if you had hondata or something i could see at least another 10 whp , much smoother graph and probably more midrange.
Old Jul 26, 2003 | 01:42 PM
FredoSP's Avatar
nice #'s, im going to be getting GSR cams in my next setup.
AaronEJ
19
Aug 7, 2012 05:57 PM
2s1owsi
Jul 25, 2007 11:55 AM
aberkrombie
Aug 13, 2003 07:23 AM
xstalkrx
May 25, 2003 06:07 PM
