Sohc, Hack, ditch the 6BTM ?
Old Jul 25, 2003 | 11:58 PM
X2BOARD's Avatar
Default Sohc, Hack, ditch the 6BTM ?
I plan to run my obd1 sohc with the afc hack. I can put in the msd6btm unit I have, but should I bother ? I will run retarded timing on the distributor otherwise, but w/o a knock sensor... should I take advantage of the btm's adjustment for safety ?
Old Jul 26, 2003 | 09:53 AM
scttydb411's Avatar
Default Re: Sohc, Hack, ditch the 6BTM ? (X2BOARD)
keep the btm so you can have better timing for off boost driving and only retard once in boost.
Old Jul 26, 2003 | 10:23 AM
X2BOARD's Avatar
Default Re: Sohc, Hack, ditch the 6BTM ? (scttydb411)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">keep the btm so you can have better timing for off boost driving and only retard once in boost.</TD></TR></TABLE>
I would love to run stock to advanced distrib. timing and just have the BTM pull it out as I build boost, but the current theory is that the afc hack causes the ecu to add timing under low rpm/low boost situations, so I'm quite reluctant to add in timing.
Old Jul 26, 2003 | 07:35 PM
TravSi's Avatar
im running 20 degree advanced timing and pulling 1 degree of timing per lb of boost.....plugs are burning great, no signs of detonation, but def. keep the btm..i ran like 13-15 base timing and boosted with no retarding and the car just idled crappy...but still pulled hard, but the off boost was just not worth it...i like having the +2 stock timing and then pull some in boost....
Trav
93civciv
Dec 4, 2007 05:23 PM
CRXLST
Oct 27, 2004 09:45 PM
BoostedD15B7
Jan 25, 2004 08:44 AM
808eg6
Jun 24, 2002 07:52 AM
boosted_el
Jan 31, 2002 02:37 PM
