not starting...
Old Jul 26, 2003 | 11:28 PM
self_made's Avatar
Default not starting...
car: 01 gsr
engine: built gsr turbo
the car doesnt start, theres no spark or fuel pressure. the grounds are good. with the key in the on position, the radio works, but the dash lights dont work, nor does the vafc. any suggestions? my thought was that it was the ecu...could it be?
Old Jul 27, 2003 | 09:27 AM
civcexcoupeblack's Avatar
Default Re: not starting... (VTECNLUDE)
Is it a stock ecu? Check fuses. Could be a lot of things. Did you install a turbo? if so what all was added? Fuel setup?
Old Jul 27, 2003 | 02:09 PM
self_made's Avatar
Default Re: not starting... (civcexcoupeblack)
its the stock ecu, fuses are good, I installed the turbo, vafc was added so was a walbro intank fuel pump and rc 450's...but the car had been running for about 2000 miles..in those 2000 miles, it turned off while drivign twice, but it turned back on...the ecu and battery had been plugged and unplugged a lot of times, could that have anything to do with it?
Old Jul 27, 2003 | 02:18 PM
You could of fried your ecu. Ive heared people say that pluggin and unpluggin the ecu can do that. Are you thowing any codes? If the CEL is solid, when you check it, that means your ECU is bad... Try borrowing a freinds. But having your car turn off while driving..sound like you have a loose ground.
Old Jul 27, 2003 | 02:29 PM
self_made's Avatar
we checked the grounds, they're good. The dash lights dont light up, so we cant tell wheather or not its throwing a code.
Old Jul 27, 2003 | 09:16 PM
Try another ECU. What ecu u need?
Old Jul 27, 2003 | 09:26 PM
self_made's Avatar
gonna try an ecu tomorrow, couldnt do it because I dont know anyone else with an obd2 gsr
Garage786
Mar 11, 2007 03:00 AM
kasso
Feb 17, 2006 07:57 AM
extrmeboost
Aug 31, 2003 05:10 PM
lude97dude
Jan 26, 2003 10:14 AM
hybridbmw
Jan 8, 2003 11:15 PM
