Reading lower boost than spring settings..
Old Jul 26, 2003 | 10:16 AM
vtec.dc2's Avatar
Default Reading lower boost than spring settings..
I'm running .3 bar spring, tial wastegate.. my gauge reads a little over .2 bar.. depending on how i punch the throttle i can notice it jump to almost .3bar for frame of a second and then stay at .2 bar.. this is consistant once i'm in full boost..
everything seems connected well together.. no strange sounds i could think off..
Old Jul 27, 2003 | 10:22 AM
integranator's Avatar
Default Re: Reading lower boost than spring settings.. (vtec.dc2)
I have the .45 bar spring in my wastegate, and I wasn't running a filter on my turbo, I was running screens, not allowing the turbo to fully spool so it only made 3psi. So something could be amiss. Good luck
Old Jul 27, 2003 | 10:49 AM
vtec.dc2's Avatar
Default Re: Reading lower boost than spring settings.. (integranator)
i'm using a filter. a small one but sufficient enough
Old Jul 27, 2003 | 06:31 PM
vtec.dc2's Avatar
ttt
Old Jul 27, 2003 | 06:38 PM
ffgeon's Avatar
where are you getting your vac/pressure source from? before or after the intercooler? the intercooler has a pressure drop. run vac line from throttle side of ic to you wg. you should see .3 bar now.l
Old Jul 28, 2003 | 07:00 PM
vtec.dc2's Avatar
Default Re: Reading lower boost than spring settings.. (ffgeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ffgeon &raquo;</TD></TR><TR><TD CLASS="quote">where are you getting your vac/pressure source from? before or after the intercooler? the intercooler has a pressure drop. run vac line from throttle side of ic to you wg. you should see .3 bar now.l</TD></TR></TABLE>
wastegate and boost gauge reads from the top of intake manifold.
Old Jul 28, 2003 | 07:53 PM
accordfreak's Avatar
that happened to me and i had a leak through one of my vacuum lines. I replaced that then no more boost leaks
Old Jul 28, 2003 | 07:57 PM
vtec.dc2's Avatar
Default Re: Reading lower boost than spring settings.. (accordfreak)
damn.. but how can you tell? everything was installed recently and looks all together..
Old Jul 28, 2003 | 08:00 PM
home made bike pump leak down test...
I bought some home depot hoses, a couple fittings...
I hooked it up the hoses to a bike pump and the turbo then pumped away..
found the leak by spraying a mist of soap and water and saw bubbles...
also heard a light hissing sound...
really easy to make.. only cost me 5 bucks minus the bike pump i already had hehe
edit: even if the problem isn't a leak.. it will be useful in the future to determine problems.. i was at .2 bars when my spring is rated at .45
Old Jul 28, 2003 | 08:16 PM
vtec.dc2's Avatar
cool.. thanks for the info.. going to try that out..
Old Jul 30, 2003 | 07:10 AM
ffgeon's Avatar
maybe turbo maifold is cracked. or turbine flange on mani isnt flat and is leaking. did you get it working?
Old Jul 30, 2003 | 06:34 PM
vtec.dc2's Avatar
the manifold is inline pro.. i hope it woudln't crack on the first days of mild boost.. i've tried the vacuum test, no hoses are leaking.. other than pressure is consistant, i can't think of nothing else..
Old Jul 31, 2003 | 04:54 PM
vtec.dc2's Avatar
tried pressure test on vaccum hoses again.. also attached another gauge to the setup.. it read 3psi.. damn..
could it be that i have 3psi spring? this is on tial 35mm wastegate, i dont have the box - but remember it said .3bar - 4.35psi spring. i don't recall them making 3psi springs for 35mm wastegate - can smaller spring be fitted into one by accident?
Old Jul 31, 2003 | 06:10 PM
vtec.dc2's Avatar
i'll put it in shorter/simpler question
can .2bar spring from Tial 46mm wastegate fit Tial 35mm wastegate?
and.. can .25bar spring from Tial 38mm or 40mm wastegate fit 35mm?
Old Aug 1, 2003 | 04:56 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote"> i'll put it in shorter/simpler question
and.. can .25bar spring from Tial 38mm or 40mm wastegate fit 35mm?</TD></TR></TABLE>
anyone?
Old Aug 2, 2003 | 11:27 AM
vtec.dc2's Avatar
ttt
user 98292739
Oct 10, 2006 05:42 PM
GSRswapandslow.
Jun 23, 2004 12:24 AM
Kwuaymaikrup
Oct 25, 2003 12:04 AM
Acura_I-RS
Sep 15, 2003 04:43 PM
salt
Jul 23, 2003 10:02 PM
