ZC DOCH motor
Old Jul 29, 2003 | 01:38 AM
93HatchCali's Avatar
Default ZC DOCH motor
if i invest in a DOCH ZC motor how much is it going to cost me to put this motor in a 93 CX hatchback, also would i have to replace any internals to boost under 10lbs?
Old Jul 29, 2003 | 01:57 AM
liam821's Avatar
25 Year Member
Default Re: ZC DOCH motor (93HatchCali)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93HatchCali &raquo;</TD></TR><TR><TD CLASS="quote">if i invest in a DOCH ZC motor how much is it going to cost me to put this motor in a 93 CX hatchback, also would i have to replace any internals to boost under 10lbs?</TD></TR></TABLE>
if you get a 2ng gen dohc ZC which is obd1 it bolts right in (obd0 you need to do some wiring). You can buy the motor from like nippon-motors.com for $600 i think. Online for cheaper. And at 10psi you will be fine leaving it stock.
liam
Old Jul 29, 2003 | 10:42 PM
Default Re: ZC DOCH motor (liam821)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liam821 &raquo;</TD></TR><TR><TD CLASS="quote">
liam</TD></TR></TABLE>
what type of clutch system does it have? is it hydrolic?
Old Jul 29, 2003 | 10:47 PM
DA-MAX's Avatar
what type of clutch system does it have? is it hydrolic?</TD></TR></TABLE>
pretty sure its cable only
Old Jul 29, 2003 | 10:48 PM
Default Re: ZC DOCH motor (DA-MAX)
would i have a problem putting a cable in replace of my hydrolic set up as it is now?
Old Jul 29, 2003 | 11:43 PM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">
pretty sure its cable only</TD></TR></TABLE>
incorrect. The 2ng gen obd1 dohc ZC came with a hydro tranny. You can use any d-series clutch. How do i know? I have a ZC hydro tranny in my garage!
liam
Old Jul 29, 2003 | 11:47 PM
Dr Drew's Avatar
I did a ZC swap into a 91 hatch. The motor ran strong and suprised me. It is a cable clutch, one of the reasons they are popular is because ppl use the civic tranny's, which is a cost savings. If you are going to do the swap...make sure the car has multiport fuel injection, not the throttle body injection setup. Wiring the injectors and such is a pain.
Old Jul 29, 2003 | 11:54 PM
Default Re: (Dr Drew)
Dr Drew
Maybe you have the first generation ZC DOCH motor, im looking into the snd gen OBD1 hopefully it wont be such a pain for me
does anyone have any experience boosting this motor on stock internals? About how mcuh HP will i be able to reach using stock internals.
thanks for all the replys.
Old Jul 30, 2003 | 12:06 AM
Charles B.'s Avatar
Default Re: (93HatchCali)
hey buddy just for future reference, it DOHC, not DOCH
also if you plan to go ZC, i would suggest the GReddy SOHC turbo kit. it was made for that motor
Old Jul 30, 2003 | 12:24 AM
Default Re: (SuperDuperEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperDuperEG &raquo;</TD></TR><TR><TD CLASS="quote">hey buddy just for future reference, it DOHC, not DOCH </TD></TR></TABLE>
woops didn't notice i typed it wrong, its been a long day
Old Jul 30, 2003 | 12:45 AM
liam821's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93HatchCali &raquo;</TD></TR><TR><TD CLASS="quote">Dr Drew
The dohc ZC bottom end is pretty much identical to the d16a6 or d16z6. Just has different pistons..and is a little big higher compression at 9.6:1.
As far as power...the head flows similar to the z6/y8 head. On the flow bench, the exhaust side flows more and the intake less. So power output is gonna be similar.
6psi is gonna be around 160-170whp. 10psi is around 200whp.
The d16 bottom end is pretty strong. There is examples of people running 16psi on a stock block and it holding. Ive personally boosted 15psi on a stock block and she held together...although i dont recommend it for everyday use.
With a good motor 10psi daily shouldnt be a problem with the right fuel management.
liam
Old Jul 30, 2003 | 02:11 AM
thanks ill be looking in to getting this motor in a couple of months or so after i shop around for parts and since school is starting up again pretty soon
also what muffler could i run with a turbo set up that doesn't have a very loud sound, gonna try to keep it as quite as i could just nothing really loud
thaks for all the help and info ill keep you guys updated
civic_frank
Aug 16, 2008 11:14 PM
i hate rice
Apr 17, 2006 09:23 AM
deerek101
Jan 8, 2006 08:25 PM
crxsijr
Apr 15, 2005 12:58 PM
JapJunkie
19
May 5, 2004 09:10 PM
