pics of low budget junk yard setup on d16 *update*
pics of low budget junk yard setup on d16- FINALLY DONE - *update*
Finished today - car runs pretty good. On way home back from test drive, the oil presure gauge line "fell off" some how and we proceeded to dump about 3 qts of oil on the road - caught it in time. went home to get tools and fixed it. All seems to be well. Exhaust leaks here and there, but they'll be fixed.
see all pics at:
http://denniscraig.org/pics/Jordans_turbo
Modified by dennis at 11:49 PM 8/10/2003
see all pics at:
Re: pics of low budget junk yard setup on d16 *update* (smb123)
YOU"RE gonna LOVE this car when your done...
I did the same thing... DSM T25 on a D15, HF manifold, plate adapter...
Running 10 psi.... so quiet....
used a wideband to set the FMU... simply amazing.
Jeffrey Atwood
Modified by Jefnes at 8:48 AM 7/28/2003
Jeffrey Atwood
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smb123 »</TD></TR><TR><TD CLASS="quote">Too bad I'm not there to weld for you monkeys! </TD></TR></TABLE>
Too bad you're not here to wire the alternator charge wire straight to ground - again
Re: pics of low budget junk yard setup on d16 *update* (dennis)
hey fawker, where's the close up pics of the super cool welding job? I need a good laugh
p.s. i have a feeling they probably look like the beads i did on my front end conversion, ha
Re: pics of low budget junk yard setup on d16 *update* (Burke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Burke »</TD></TR><TR><TD CLASS="quote">is there an ic????
looks good so far
Good luck!!!</TD></TR></TABLE>
From the pics, looks like he's using a DSM SMIC. Good luck with the homemade setup. Looks good so far.
looks good so far
Guest
Posts: n/a
Re: (J. Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">Done? I'm waiting for you to get the Y8 swap running in the first place.</TD></TR></TABLE>
y8 is ready to crank, as soon as i get the bolt for the fuel rail and get the front suspension and main relay settled.
Good, Bad…I'm the one with the gun
Location: Trapped in time, Surrounded by evil, Low on gas
1 Post
Don't feel bad, aluminized steel is ***** to weld, regardless of the welder or the equipment.
great job!
stan
great job!
stan
New User
Re: pics of low budget junk yard setup on d16- FINALLY DONE - *update* (dennis)
Any chance that is the RGAZ/GJC Randy and Gary adapter?? Sure looks like ours.
I hope you enjoy it, it should work good for a long time. Its an easy 10psi turbo kit for low bucks.
Randy
Randy
Re: pics of low budget junk yard setup on d16- FINALLY DONE - *update* (RGAZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGAZ »</TD></TR><TR><TD CLASS="quote">Any chance that is the RGAZ/GJC Randy and Gary adapter?? Sure looks like ours.
Randy</TD></TR></TABLE>
Hmm, I'm not exactly sure. He got it off Ebay and I think it came from LA?
you should have seen him on his maiden voyage. He was all nervous, but once he got on it.... BIG SMILES. Although it turned to a frown again when we saw we had no oil pressure and dumped 3qts behind us. Other than that, the car drives pretty damn good. Seems to idle a little higher and some surging - not sure if it's related to the blue box or not. We did bypass the IAC, but that shouldn't effect anything once it's warmed up.
Thanks for the replies
Vice President/CEO
love custom buildups. I wanna finish my custom build soon... ugh.
Great pictures BTW... crazy group you and ur friends are'
Took her to the track last night. Jordan only did two runs. Keep in mind that this thing was running a 16.6 with the stock d16 - he got a 15 flat on his second run. Not record breaking, but impressive given how cheap we built this
OG triple OG
tickle the motor and youll be in the 14's
what kind of fuel/engine management do you have in this thing?????
Re: pics of low budget junk yard setup on d16- FINALLY DONE - *update* (Tur*bLu)
it was way under a grand - don't have exact numbers, but we're running a t25 on a hf manifold with the adapter. DSM SMIC, Using a dsm bov and blue box for management. Haven't run the wideband across it yet, but it's running really well. Going to pull the plugs this weekend and have a look.
Re: (TURBO B)
Hang in there with the welding.. I got a MIG setup and am learning how to handle leakfree welding.. although it's a challenge. Getting better.
racinskittle
09-27-2003 04:05 PM
Elite Hatch
10-19-2002 10:46 AM
