if u could start out with any engine for FI what would u use
ok thats your question...if u could start over...with any engine what would u use...im kinda scaring myself i guess because im pickin up a car with a ls vtec and i havent really seen many people with big numbers using them
Re: if u could start out with any engine for FI what would u use (boostCreep)
the ls vtec will make a ton of power and good torque if the engine is built. look on hondata.com they have a LS vtec tubro setup thats making like 640WHP.
any engine? if it had to be honda i'd just keep it simple and go gsr. any any engine at all? sr20det hands down
Re: if u could start out with any engine for FI what would u use (Pengo)
yea this trial user stuff sux...i make a post then i hit my limit
anyway i found that dyno slip....that helps a bunch...i guess ill definatly be goin all out on this motor
Re: if u could start out with any engine for FI what would u use (redteg1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redteg1 »</TD></TR><TR><TD CLASS="quote">2JZGTE</TD></TR></TABLE>
i agree...i fully beleive this is the best motor ever built....the power capabilities are mind boggling...9 second passes without ever separating the head from the block
Re: if u could start out with any engine for FI what would u use (HondaGuRu)
id go with a dart 1.8l or 2.0l closed deck honda block and a worked on non vtec head....the bare blocks are roughly 2500 i think and all stock components bolt to them....with a set of internals, you can make some serious power without the worries of the open deck block....someday when i have more money thats the route im going...
Trav
Trav
Re: if u could start out with any engine for FI what would u use (ekb18c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">2JZGTE</TD></TR></TABLE>
I would have to whole heartedly agree with that one.
Re: if u could start out with any engine for FI what would u use (turbozxi)
I'm not shooting for the stars, I would keep my resilient lil B18B, it takes beatings like a champ. I am going to get it sleeved and get a semi built head probably 6 months down the road... Basically it all boils down to $$$ for me, I don't wanna blow something I can't afford to replace
Re: if u could start out with any engine for FI what would u use (Accord94DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord94DX »</TD></TR><TR><TD CLASS="quote">h23a1</TD></TR></TABLE>
With a HKS T51R.
With a HKS T51R.
For sure
So easy to get so much power out of
For sure
Absofuckinglutely!!!
Re: if u could start out with any engine for FI what would u use (hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridsol »</TD></TR><TR><TD CLASS="quote">Come'on... B18B w/ B16 head. Cheap+power.</TD></TR></TABLE>
dose the b16 head flow better than a type r head?...im gonna start searching on this but the car im buyin is a ls vtec with itr internals and itr head...
:edit: ok i guess the heads are the same but the valvetrain and cams are different...nothin big if your gonna redo everythin anyway
Guest
Posts: n/a
