headgasket?
Old Jul 29, 2003 | 07:55 AM
DXturbo's Avatar
Default coolant issues/problems....
okay so heres the deal... i have a d16z6 with the apexi turbo kit intercooler and everything else... the problem that im having with my coolant. im driving and next thing you know im smelling coolant. i pull off to the side and pop the hood and coolant is spraying all over my engine bay. cant tell wheres its spraying from but my resovior tank is FULL.
i checked the oil and there was no signs of coolant mixing.
i believe that i did not bleed the coolant system right... might still be bubbles in the system - if there is air in the system could it overpressurize the system causing it to overflow?
could it be a BLOWN headgasket?
TIA
Modified by DXturbo at 10:26 AM 7/29/2003
Old Jul 29, 2003 | 09:53 AM
DXturbo's Avatar
Default Re: coolant issues/problems.... (DXturbo)
ttt...
Old Jul 29, 2003 | 03:18 PM
DXturbo's Avatar
anyone?????
Old Jul 29, 2003 | 03:22 PM
intekragsr's Avatar
its blown......
check under your oil cap and tell us what you find.
Old Jul 29, 2003 | 03:26 PM
ekb18c's Avatar
head gasket..
Old Jul 29, 2003 | 10:41 PM
DXturbo's Avatar
Default Re: coolant issues/problems.... (ekb18c)
thanks guys but i figured it out. one of the coolant hose busted but you really couldnt see it cause it was under the distributer. thanks though... cars running flawless again. thanks!
Old Aug 1, 2003 | 06:42 AM
M.A.R.C.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXturbo &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys but i figured it out. one of the coolant hose busted but you really couldnt see it cause it was under the distributer. thanks though... cars running flawless again. thanks!</TD></TR></TABLE>
EXACT thing happened to me... except i found out one day while driving on the highway in the middle of the rain
Hoopdie91
Apr 3, 2016 06:15 AM
tianporn
Feb 26, 2011 10:58 PM
bandit080000
Honda Civic (2001 - 2005)
Jul 1, 2010 11:09 AM
Bunta eg6
Nov 13, 2005 02:11 PM
lavo81
Aug 8, 2005 12:05 PM
