Turbo seals / oil line press (h22)
i saw this thread a while ago , and can't find it. I saw someone that posted up about their seals on their turbo going only after a couple thousand miles due to the fact that our h series has such high oil pres at high revs.,
so the question is
what size oil line do you guys use?
and do you use some time or restrictor so that the turbo seals don't see to much oil press?
and whats the max oil press a turbo needs to stay healthy?
so the question is
Re: Turbo seals / oil line press (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO »</TD></TR><TR><TD CLASS="quote">i've heard from many sources that 35 psi is a good pressure for a turbo, if constant is better</TD></TR></TABLE>
really ? then what am i supposed to do , my oil press peaks around 100spi at high revs, should i use a very small supply line, or pus a restrictor in?
Re: Turbo seals / oil line press (prelittlelude)
I read somehwhere a while back that most garrett turbos only require 10psi although of course you can give it a lot more.
mister2racer
05-10-2012 06:12 AM
