knocking noise under load...
Old Jul 25, 2003 | 12:47 PM
slowsi00's Avatar
Default knocking noise under load...
well ok i just took my car on a long ride about 2 hours
now when i press on the gas while in lower rpms ranges i get a wierd knocking noise. it goes away if i take it up in rpms. but i dont want to do that
boost is set and holds at 10psi
could it be my wastegate?
ic looks fine
all ic piping is still on
maybe turbo is seizing up?
but i just bought a brand new precision sc61
i have no more ideas of what it could be
Old Jul 25, 2003 | 01:02 PM
Poop111444's Avatar
Default Re: knocking noise under load... (slowsi00)
Do a valve adjustment.....although typically if they were out of spec, then the ticking would increase with RPMs....
Old Jul 25, 2003 | 01:15 PM
mos's Avatar
mos
Default Re: knocking noise under load... (si_mekanik)
Retard your ignition timing and see if the noise goes away.
Old Jul 25, 2003 | 01:49 PM
slowsi00's Avatar
Default Re: knocking noise under load... (mos)
my tuner thiks its a rod knock but wouldn't that happen throught the entire rpm range?
and it seems liek ti coming from the head
Old Jul 25, 2003 | 02:04 PM
93LSivic's Avatar
I had a knocking noise. Now Im about to buy another motor.
Get that **** checked out fast.
Old Jul 26, 2003 | 11:08 PM
iiilgsrlll's Avatar
I have the same problem on my GS-R. Knocks in low end but goes away in higher rpm's. Please post what it ends up being. I would like to know.
TIA
Old Jul 26, 2003 | 11:25 PM
slowsi00's Avatar
Default Re: knocking noise under load... (iiilgsrlll)
i am not driving the car
i am trailoring it to the shop so they can determine what it is.... rod knock, clutch/flywheel issue, head issue?
i t sounds like its coming above number 3 in the head. we will find out soon like monday or tuesday.
its not mroe of a knocking but mroe off a clicking...
Old Jul 26, 2003 | 11:32 PM
authentic plusONErandy's Avatar
has the problem been solved? im having a similiar problem =/
Old Jul 26, 2003 | 11:48 PM
romeo619romeo's Avatar
Default Re: (jdm1.8LSi)
same here.. id liek to kno.. at times i think its small detonation..at low rpm..
Old Jul 27, 2003 | 08:11 AM
slowsi00's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm1.8LSi &raquo;</TD></TR><TR><TD CLASS="quote">has the problem been solved? im having a similiar problem =/</TD></TR></TABLE>
i will be trailoring the car there monday or tuesday
Old Jul 27, 2003 | 10:51 AM
TravSi's Avatar
Default Re: (slowsi00)
ITS DETONATION!!!!! geez lousie, sounds like someone taking marbles in a jar and shaking them....i had that too...but now retarding timing into boost and i no longer have partial throttle knock...knock is worse under loading and thats what yur hearing, nothing more nothing less... and its not hard to fix just retard timing until it goes away, or dont do partial throttle boost, go more than half or full throttle, but gets hard when yur going up hills and such cause under load the car wants to go into boost...thats what i did for a while but then programmed the ecu to pull timing in boost, works great now.....The knock you can hear like that is bad, start checking plugs and look for signs of detonation, unless you have a j&s to monitor knock you just have to play with timing and fuel and watching plugs
Trav
Old Jul 27, 2003 | 11:06 AM
iiilgsrlll's Avatar
Default Re: (RexSiT3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexSiT3 &raquo;</TD></TR><TR><TD CLASS="quote">....its not hard to fix just retard timing until it goes away, or dont do partial throttle boost, go more than half or full throttle, but gets hard when yur going up hills and such cause under load the car wants to go into boost.......
Trav </TD></TR></TABLE>
Sounds like me. When I go up steep hills it does it a lot more.
Old Jul 27, 2003 | 11:48 AM
rjardy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RexSiT3 &raquo;</TD></TR><TR><TD CLASS="quote">ITS DETONATION!!!!! geez lousie, sounds like someone taking marbles in a jar and shaking them....i had that too...but now retarding timing into boost and i no longer have partial throttle knock...knock is worse under loading and thats what yur hearing, nothing more nothing less... and its not hard to fix just retard timing until it goes away, or dont do partial throttle boost, go more than half or full throttle, but gets hard when yur going up hills and such cause under load the car wants to go into boost...thats what i did for a while but then programmed the ecu to pull timing in boost, works great now.....The knock you can hear like that is bad, start checking plugs and look for signs of detonation, unless you have a j&s to monitor knock you just have to play with timing and fuel and watching plugs
I am glad that someone said that. I was reading the post and I knew what it was and people were talking baout '"wonder what it is" . Personally I think that Its is of upmost importance that people no about detonation/preignition, if they venture into turbo........my two cents
Rob
Old Jul 27, 2003 | 12:17 PM
TravSi's Avatar
Default Re: (rjardy)
you better believe it....its very important to understand, its one of the most important aspects to monitor on a turbo motor, detonation will own you!!
Trav
Old Jul 27, 2003 | 12:24 PM
danl's Avatar
Banned
Where are all the guys who like to run 14:1 compression and low boost? Maybe they'd like to tell me now how easy it is to tune out etc.....
EDIT: If you're running the afc hack it likes to provide to much part throttle timing when you're boosting slightly up a hill or something. Either pull back the base timing, run a boost retard setup, change the timing maps in the ecu, or what i'd recommend run a J&S safegaurd and mechanically pull timing with boost as well as have the J&S in the background listening for detonation and having the ability to pull timing. SOme people don't get the fact that when the weather changes from your tuning session, its very EASY to run into detonation problems. If you tune in the day, and race at night you are very well out of tune and maybe detonating. An active device to pull timing is a really good idea on a street car. But WTF do I know, i drive a mitsubishi
Old Jul 27, 2003 | 01:55 PM
slowsi00's Avatar
Default Re: (danl)
i know what detonation sounds like
and this is not it.
its a mechanical problem.
Old Jul 28, 2003 | 09:19 AM
spooned out's Avatar
I too hear this, onlyhear it when its at idle, can't hear it from engine bay only when sitting in the car ( this is even before boosting ), running like that for about 1yr no problems but still i would like to knoe what you find out.
Old Jul 28, 2003 | 09:26 AM
PM-Performance's Avatar
Default Re: (spooned out)
piston slap? are these built motors or no?
mine doe sit a little at idle, but the piston to wall clearances we left a little looser becuase oft he power output and boostlevels i plan on making , so mine is more thna likley pistons slap . kinda sounds like a turbo deisel VW?
Old Jul 28, 2003 | 10:02 AM
iiilgsrlll's Avatar
Default Re: (itr206)
Don't know about Slowsi00 but my motor isn't built. If his problems are the same as mine the problem doesn't happen at idle. It only happens when the motor is under load in the lower rpm range. Mine also occurs with no boost in the lower rpm range under more than half throttle.
Old Jul 28, 2003 | 10:10 AM
Default Re: (iiilgsrlll)
oh mine only happens at idle that i notice. i didnt see that
Old Jul 28, 2003 | 12:20 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsi00 &raquo;</TD></TR><TR><TD CLASS="quote">i know what detonation sounds like
and this is not it.
its a mechanical problem.</TD></TR></TABLE>
Yeah, if you isolated it to the (possibly) #3 cylinder, then you are either mentally retarded, or it does it when not under load so you could listen under the hood so it's not detonation but, RexSiT3 should get points for enthusiasm...or not.
Old Jul 28, 2003 | 01:12 PM
slowsi00's Avatar
my motor has rods and pistons on the stock sleeves
its not pistons slpa since it this issue just came up piston slap would have been there since day one
the motor has about 7000 miles on it
i take it in on wensday to figure out what is going on
Old Oct 31, 2003 | 11:02 AM
slowsi00's Avatar
just to let everyone know
this was a rod bearing issues and the bearing ened up dropping in my oil pan
98coupeek
Nov 24, 2009 08:15 AM
Mikeman191
May 2, 2003 01:36 PM
turbogsr13z
Jul 30, 2002 05:06 AM
you2envious
Jun 21, 2002 04:00 PM
