better engine to turbo B or H
Old Jul 28, 2003 | 12:22 PM
tonesdef's Avatar
Default better engine to turbo B or H
the B18c1 or the H22 the H22 is appealing becuase its cheap as **** but people seem to have problems with axles and i heard that the ringlandings can't handle that much boost. I've seen more b18's turbo than H22 but the H22 in a hatch would be faster off the bat so would it also be faster with a rev hard kit than a b18c1 with a rev hard kit
Old Jul 28, 2003 | 12:39 PM
Kwuaymaikrup's Avatar
Default Re: better engine to turbo B or H (tonesdef)
I would say go with the B18c for simplicity reasons....more readily available aftermarket support.
Old Jul 28, 2003 | 12:57 PM
tonesdef's Avatar
so i got one reply sofar
Old Jul 28, 2003 | 01:53 PM
tegrakid's Avatar
H22 suck there side walls are made some kind of material that cant take boost all that well. my friend put a set of aftermarket pistons in his it destoryed the side walls now its getting sleeved. h22 is also more heavier than the b series, but by far there are far more bseries parts than h22 parts. i could go on forever how great a b series is and how abundant parts are for them but you make your own judgement.
Old Jul 28, 2003 | 02:47 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: better engine to turbo B or H (tegrakid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegrakid &raquo;</TD></TR><TR><TD CLASS="quote">H22 suck there side walls are made some kind of material that cant take boost all that well. my friend put a set of aftermarket pistons in his it destoryed the side walls now its getting sleeved. h22 is also more heavier than the b series, but by far there are far more bseries parts than h22 parts. i could go on forever how great a b series is and how abundant parts are for them but you make your own judgement.</TD></TR></TABLE>
Side Walls.......and what kind of material is that.
Well my friend has one and his hasn't bother him one bit. Been boostin for about 6 months. I would say b but if you can afford h I would say H
Old Jul 28, 2003 | 02:51 PM
DLB1994's Avatar
Default Re: better engine to turbo B or H (HybridcivicLS-T)
if the engine is stock ill go with a B but if bulit ill get a H block any day
Old Jul 28, 2003 | 02:57 PM
jacksonracingsi's Avatar
the cylinder walls of the H22 is made differently than the b series. This factor has nothing to do with boost, but it does with forged pistons...so if you are planning on running a stock bottom end you shouldn't care at all. If you are going to build the bottom end, you will have to sleeve the h22.
personally, i would build up a b18c over a h22 anyday.
Old Jul 28, 2003 | 04:59 PM
turbotypeR@SPEC's Avatar
25 Year Member
i say h22.bigger is better.i have a customer that makes 290whp@3200rpm in his stock h22 with t3.
Old Jul 28, 2003 | 05:09 PM
Finest's Avatar
Default Re: better engine to turbo B or H (turbotypeR)
Watch out for those H series oilpumps.
Any motor can be made to go quick...pick your poison.
Old Jul 28, 2003 | 05:12 PM
mskibbz-T's Avatar
Default Re: better engine to turbo B or H (98CTRCoupe)
I would go B series without a doubt. H series bottom ends aren't as strong stock for stock... and then if you wanna make big power, notice how many fast big power hondas run an H series and how many run a B series. Almost all run a B series. Just my $.02
Old Jul 28, 2003 | 05:45 PM
turbologist's Avatar
B micki-ficki, B !!!!!!
civtic
48
Feb 11, 2008 07:47 PM
oem_certified_accord
Aug 3, 2007 09:13 AM
deucedeuceEK
Apr 26, 2006 05:56 PM
belz513
Nov 30, 2005 08:49 AM
Acutang
Oct 8, 2004 02:16 PM
