will a frountmount work with cai
Old Jul 28, 2003 | 07:36 PM
mrcivicsi2k's Avatar
Default will a frountmount work with cai
ok this might be a stupid question but i just bought a turbo kit for my si and it has a spearco fmic will i be able to use my cai or do i need to get rid of it for a short ram because on my friends wrx with a fmic he couldnt run his cai thanks for the guys
Modified by mrcivicsi2k at 5:59 PM 7/29/2003
Old Jul 28, 2003 | 07:41 PM
nigel's Avatar
those are two different cars mang. you can use a cai for a charge pipe, and you probably have to add on a 90 degree bend. is your car even turbo?
Old Jul 28, 2003 | 07:49 PM
1dumbscreenname's Avatar
Default Re: will a frountmount work with cai (mrcivicsi2k)
probably not.
Old Jul 28, 2003 | 08:39 PM
InTeGrA B18b1's Avatar
you could use it but itll have to be custom work and you need some where to put your bov
Old Jul 29, 2003 | 12:39 AM
nigel's Avatar
if you want to use an aluminum cai for a charge pipe you will have to either make an alluminum flange which is easy with alluminum. for you have to order it.
Old Jul 29, 2003 | 07:58 AM
mamaboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrcivicsi2k &raquo;</TD></TR><TR><TD CLASS="quote">ok this might be a stupid question but i just bought a turbo kit for my si and it has a spearco fmic will a be able to use my cai or do i need to get rid of it for a short ram because my friends with wrx's with fmic's couldnt run cai thanks for the guys</TD></TR></TABLE>
???? get rid of it for a short ram????? keep this in mind.....turbo compressor &gt;&gt; intercooler &gt;&gt;&gt; charge pipe &gt;&gt;&gt; throttle body....CAI's are too big big for low boost apps. you will need to fabricate a charge pipe from throttle body to intercooler....and intercooler to the compressor......SEARCH
Old Jul 29, 2003 | 08:54 AM
sk8rmike's Avatar
Default Re: will a frountmount work with cai (mamaboy)
yeah man, you dont use an intake when you're boosting. the IC piping goes right from the IC to the TB
Old Jul 29, 2003 | 09:33 AM
redlinegsr's Avatar
Default Re: will a frountmount work with cai (sk8rmike)
wow did he really ask that question...i guess i take for granted my knowledge but i thought that was common sense
Old Jul 29, 2003 | 10:03 AM
BoostedsiR's Avatar
Default Re: will a frountmount work with cai (redlinegsr)
maybe if he asked about doing that for a charge pipe but **** can somebody shut this post down
Old Jul 29, 2003 | 10:07 AM
quikB18B's Avatar
Default Re: will a frountmount work with cai (BoostedsiR)
Using your short ram for intercooler piping may save you $12, go to JCwhitney and piece together your bends u need to complete your piping. Also if im not mistaken the question he asked want if he could use it for intercooler piping, i think he was meaning if he still retains it? WTF i dont know i read it 3 times and didnt understand. Either way pull your bumper off and you can jusge for yourself which bends u need. Enough said someone lock this for real.
Old Jul 30, 2003 | 12:42 PM
legendboy's Avatar
Default Re: will a frountmount work with cai (quikB18B)
Full AEM CAI
Old Jul 30, 2003 | 01:08 PM
Carlito Brigante's Avatar
Default Re: will a frountmount work with cai (legendboy)
i think what he means is can he use his aem cold air intake for the intake on the turbo inlet.
Old Jul 30, 2003 | 01:26 PM
quikB18B's Avatar
Default Re: will a frountmount work with cai (em1-t)
I dont think he's asking about using it for intercooler piping because why woudl he say something about swapping to a short ram, I give up this post is retarded.
Old Jul 30, 2003 | 07:42 PM
integrx's Avatar
New User
dude, with your knowledge, please bring it to a shop to install or kiss your motor good bye
Old Jul 30, 2003 | 09:23 PM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrcivicsi2k &raquo;</TD></TR><TR><TD CLASS="quote">ok this might be a stupid question but i just bought a turbo kit for my si and it has a spearco fmic will i be able to use my cai or do i need to get rid of it for a short ram because on my friends wrx with a fmic he couldnt run his cai thanks for the guys
Modified by mrcivicsi2k at 5:59 PM 7/29/2003</TD></TR></TABLE>
the reason your friend couldnt run a cai on his wrx was because the cai runs thru the same fender well that the intercooler piping goes thru. its not the same on a honda. you can run a cai on a turbo car but not the wrx with a front mount.
Old Jul 30, 2003 | 09:25 PM
falcongsr's Avatar
What is this crap?
Default Re: will a frountmount work with cai (MotorMatrix.com)
this thread is well on its way to being a "B3st Thrad eVaR!" nominee for 2003.
Old Jul 30, 2003 | 09:34 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">
the reason your friend couldnt run a cai on his wrx was because the cai runs thru the same fender well that the intercooler piping goes thru. its not the same on a honda. you can run a cai on a turbo car but not the wrx.</TD></TR></TABLE>
Actually, I just installed a CAI on a WRX w/FMIC. He's running a VF30 with the APS FMIC. You just have to carefully shoehorn the silicon connector thru the fenderhole and use a smaller/thinner K&N cone filter in the fenderwell. Boost response picked up noticeably in the mid/high rpm range.
Old Jul 30, 2003 | 09:41 PM
I am a bad person
Default Re: will a frountmount work with cai (98CTRCoupe)
you can fab it up to work i guess. most of the kits usually require you to go with their short ram intake or the provide a short ram with the kit. i was more or less giving the guy an idea of why his buddy said he cant run a cai on his wrx.
Old Jul 30, 2003 | 10:28 PM
DLOTYPER's Avatar
this is ****** great,, the kid was asking if he could run a cai to the inlet on his turbo,,,, what didnt anybody get here? why the **** would he rig the aem up on his **** if he "just bought a turbo kit" for his 99 si?????? shut this **** down...........haha
Old Jul 30, 2003 | 10:45 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMatrix.com &raquo;</TD></TR><TR><TD CLASS="quote">i was more or less giving the guy an idea of why his buddy said he cant run a cai on his wrx.</TD></TR></TABLE>
Yea, I understand...just playing "Devil's Advocate".
Old Sep 9, 2003 | 08:36 AM
Hoosier Daddy's Avatar
What the **** is going on in here?!
Old Apr 8, 2004 | 06:34 AM
scratchy's Avatar
you are a complete moron you are one of those **** that just buys stuff and has somebody else do the work, you have to be dumb as a brick so sit back and read you might learn something or you can just pay somebody else to do it for you
Old Apr 8, 2004 | 06:41 AM
Red CiViC Hatch's Avatar
Default Re: will a frountmount work with cai (scratchy)
why did u bring this thread back up?
tytyguy
Apr 13, 2006 01:40 PM
ORcivicsi
Mar 16, 2005 09:12 PM
cambopheonix56
May 19, 2004 09:46 AM
thaiphob
May 29, 2003 08:26 PM
bluebullet
Jul 3, 2002 08:15 AM
