sleeving the block
Old Oct 14, 2003 | 12:17 PM
projectTeG's Avatar
Default sleeving the block
hey do i need to sleeve a block to run about 10-15 psi in a b18a1?or could i just drop the c/r and get forged rods?
Old Oct 14, 2003 | 12:29 PM
DaveF's Avatar
Default Re: sleeving the block (projectTeG)
you can run that amount of boost on stock bottom end if the tune is right.
Old Oct 14, 2003 | 01:26 PM
-iLLuZioN-B18C1's Avatar
Default Re: sleeving the block (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">you can run that amount of boost on stock bottom end if the tune is right.</TD></TR></TABLE>
but you could throw in the forged pistons and rods for more security
Old Oct 14, 2003 | 01:33 PM
*Boostwerks*'s Avatar
While this is mostly true, "10-15psi" without respect to flow is extreemly vauge.
You should be able to do 300hp tuned properly on stock internals.
97grnrs
Jan 6, 2008 07:07 PM
BmfoHPWW
Sep 22, 2007 09:42 AM
luder2_2vtec97
Aug 18, 2006 06:16 AM
darkblue1998ls
Jan 19, 2006 07:42 PM
B18 CYA
Apr 7, 2004 03:43 PM
