How much Headwork should be done??
Old Oct 14, 2003 | 07:39 AM
integranator's Avatar
Default How much Headwork should be done??
I am going to do a small build, and boost around 16psi daily. I was wondering what kind of headwork do you all recommend? I have an LS motor, and i've heard the head flow is TERRIBLE, so would you all recommend a race PnP? Also, would u recommend some decent valves, like Skunk2? I don't plan on taking the rev's past stock. Let me know what you think!
Old Oct 16, 2003 | 05:13 PM
Default Re: How much Headwork should be done?? (integranator)
anyone?
Old Oct 16, 2003 | 06:25 PM
hybrid93SIvic's Avatar
get a b16 head and you will be set
Old Oct 16, 2003 | 06:26 PM
Muckman's Avatar
Moderator in Chief
Default Re: How much Headwork should be done?? (hybrid93SIvic)
does a B16 head flow better than an ITR head?
Old Oct 16, 2003 | 06:27 PM
trbob16a's Avatar
Default Re: How much Headwork should be done?? (Muckman)
No, but they can be found a lot cheaper. B16 head plus some itr valve springs is a good setup and can be had pretty cheap.
Old Oct 16, 2003 | 06:31 PM
Default Re: How much Headwork should be done?? (trbob16a)
I didn't really want to go ls/vtec, i just wanted to stay w/out vtec
Old Oct 16, 2003 | 06:41 PM
intekragsr's Avatar
I think it may just be worth doing an ls/vtec.
If you want to keep the LS head, just call up Alaniz, Endyn, or Portflow and ask them what kind of work they recommend. I called Alaniz one time and he seemed very helpful and didnt mind taking time in explaing what he can do for me. That would be better than getting a bunch of mixed opinions on the boards. IMO
Old Oct 16, 2003 | 06:52 PM
Default Re: How much Headwork should be done?? (intekragsr)
my main question is-- Will the stock valves be fine for around 14-18psi on my car??
Old Oct 16, 2003 | 08:36 PM
11psiTurboSI's Avatar
This guy I know boost 18psi daily and 25psi at the track with a stock ls head with no problems!
HeadlesNorseman
Dec 6, 2014 10:44 PM
hatchyAllday
Feb 27, 2008 04:02 AM
DAintegra
Dec 1, 2004 02:37 PM
es four
Aug 15, 2002 05:49 AM
delsolracer
Jul 19, 2001 06:06 AM
