What Size turbo for 2.0 gsr?
I am breaking in my new turbo motor now. I need to know what size turbo to run with 84mm je pistons-golden eagle sleeves-eagle rods in a jdm b18c block..stock gsr head with a valve job. I am running hondata 2b with 750 cc injectors. What turbo would be the most efficent?thank-- ohh 9.0.1 compression pistons
Re: What Size turbo for 2.0 gsr? (GSRT37)
how much power are you trying to make?
edit - a t3/60-1 would be the safest bet for you. Not too much lag and enough punch to make you smile.
Modified by ekb18c at 8:14 PM 10/13/2003
Re: What Size turbo for 2.0 gsr? (ekb18c)
I want as much power as i can get out of stock fuel lines. I was told the max out at 340 hp...i have a 255 lph pump and was thinking about adding an inline also because i dont want the loud *** aeromotive one and its 2 much money. 60-1 sounds like a good choice. Best place to get one???? I like the prec turbos also...
