b16a Sleeves
Old Oct 13, 2003 | 08:31 AM
Outkast_CL9's Avatar
Default b16a Sleeves
Just want to know about what is the max pressure the stock b16a sleeves can handle? If I was going to go turbo I would keep the pressure at about 12 to 15 psi...
Old Oct 13, 2003 | 08:50 AM
ricodemus's Avatar
Default Re: b16a Sleeves (Outkast_EF8)
well, the turbo's boost pressure isn't the number you are looking for. Turbos flow different volumes of air at the same boost pressure, yielding different amounts of power. Internal pressures and temperatures are more what you are concerned about, which is relative more to horsepower, not boost pressure.
then a concrete number cannot be established because a lot matters in the tune/fuel management. I plenty of people have made 250-270 hp on stock b16s and they hold up just fine. Others have made even more with forged pistons and rods while maintaining stock sleeves.
Old Oct 13, 2003 | 12:53 PM
TurboJesse
Guest
Posts: n/a
Default Re: b16a Sleeves (ricodemus)
People have made over 500whp on b series stock sleeves, theres so many variables to give a def answer.
extremeracer
Oct 28, 2010 02:10 PM
mrchris1979
Feb 15, 2008 12:13 PM
DrivinVtec
Sep 30, 2007 08:04 PM
swappedb16teg
Aug 30, 2004 04:05 PM
fire7882
Sep 29, 2002 04:44 PM
