Headgasket Question.....(Not how to Install)
Old Oct 13, 2003 | 01:19 PM
9200RPM's Avatar
Default Headgasket Question.....(Not how to Install)
First off my bottom end consists of B16a with JE 10.5:1's, Eagle H Beams, block is sealed, head studs, balanced....all that good stuff. I'm putting a Garrett T3/T04e 57 trim .63 a/r on it next week. I talked to a few of my VW buddies and they told me about stacking head gaskets to drop compression; ie. (factory metal, copper, factory metal). Is this possible on a Honda?? If so then if I do the FM, Copper, FM; will I still have to O-Ring the head. Thanks for any and all help.
Cameron
Old Oct 13, 2003 | 01:35 PM
intekragsr's Avatar
Default Re: Headgasket Question.....(Not how to Install) (TurboB16aEG)
Just specify to cometic or inline pro what thickness headgasket you need. OEM gaskets are not made to stack.....
Old Oct 13, 2003 | 01:37 PM
TeStUdO's Avatar
Default Re: Headgasket Question.....(Not how to Install) (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">Just specify to cometic or inline pro what thickness headgasket you need. OEM gaskets are not made to stack.....</TD></TR></TABLE>
Yeah it wont seal right if you stack stock ones
EDIT: What are you using for fuel management for your project?
Old Oct 13, 2003 | 02:20 PM
9200RPM's Avatar
Default Re: Headgasket Question.....(Not how to Install) (TeStUdO)
Well fuel managment is going to be done my friend Steven (SpeedPhreak).
We are trailering the car to a dyno and and he is writing me a honda program to read pressure and to run the 450 cc's I'm using. I trust him with my car, therefore I trust him with my life.... For any future tuning I have a wideband for montoring.
Old Oct 13, 2003 | 02:25 PM
Tofurky's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboB16aEG &raquo;</TD></TR><TR><TD CLASS="quote">I talked to a few of my VW buddies and they told me about stacking head gaskets to drop compression;</TD></TR></TABLE>
Funny, my VW buddies say the same thing.
Old Oct 13, 2003 | 03:35 PM
9200RPM's Avatar
Default Re: Headgasket Question.....(Not how to Install) (Tofurky)
Can you stack 2 Copper gaskets together. I have two .43" copper gaskets...And I have heard O-Ring is necessary and un-necessary...So any help there would be greatly apprecciated...Thanks again
Cameron
blackccoupe
Aug 27, 2008 08:52 PM
94integragsr
Feb 12, 2006 02:24 PM
Bigjussin
11
Apr 16, 2005 02:57 PM
mrx
Oct 2, 2004 09:08 PM
saso
Jun 3, 2003 09:29 PM
