Getting CEL for Map sensor with Missinglink @ 4.5 psi....??
Old Oct 13, 2003 | 08:06 AM
Integra_Boi's Avatar
New User
Default Getting CEL for Map sensor with Missinglink @ 4.5 psi....??
haven't had this problem since i had the missing link installed but recently i've been getting it from boost. I think i read somewhere back then about cleaning the hole of the missing link?
Old Oct 13, 2003 | 08:16 AM
VTC_CiViC's Avatar
Default Re: Getting CEL for Map sensor with Missinglink @ 4.5 psi....?? (Integra_Boi)
Yep, happend to me after like a month or two of using the missing link. Gotta clean that little hole gently with a pin.
Old Oct 13, 2003 | 02:22 PM
Distorted's Avatar
Default Re: Getting CEL for Map sensor with Missinglink @ 4.5 psi....?? (VTC_CiViC)
Oddly enough, at 4.5 psi, Your missing link isn't doing anything but looking pretty. You have to break 10.25 psi or so for it to start being effective. All it will do is bleed off the excess pressure after this point. If its causing you problems, take it off, check your map sensor to make sure its functioning properly.
Old Oct 22, 2003 | 07:55 AM
New User
Default Re: Getting CEL for Map sensor with Missinglink @ 4.5 psi....?? (Distorted)
It was cuz i have a boost leak but i'm back at 6.5 for now.. but yea.. if i dont have a missing link, i'll definetly get a CEL into safety mode though..
elpiar
Mar 22, 2005 06:02 PM
94greddycivic
Jun 29, 2004 10:51 AM
TurboLude97
Apr 30, 2003 05:12 AM
01ITR#700
Mar 4, 2003 12:17 PM
