how much $$$?
Re: how much $$$? (2K_TEG)
revhard is a great turbo kit but you should also figure on getting a clutch, bigger exhaust, and like Kyle said once its on you will want more and more... very addicting and you will probably end up upgrading all the parts in the end. just do your research this is a great site to find anything you need.
Re: how much $$$? (inJDMtegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inJDMtegra »</TD></TR><TR><TD CLASS="quote">more info...will i need hondata,injectors,FMU,fuel pump? just to run 8lbs?
thanks guys! </TD></TR></TABLE>
if you are running 8, i doubt you need a hondata. i think you just need to change ur clutch, and exhaust. also, upgrade your feul system. having hondata won' t hurt tho.
8 psi...i suggest uberdata, 310cc-450cc injectors, new fuel pump couldnt hurt but isnt necessary. new clutch isnt necessary if the car is only 3-4 years old....will it be harder to shift? yes...but atleast blow your current clutch....make it more fun
give me a call tomorrow, I will explain it all. Lots to type.
You can even call on my dime 800-WIRED-80
