ngk spark plugs for d16z6 turbo
I did a search and got more confused than where i started.... lol
Putting on my greddy turbo kit this week (tdo4-15g)
Now i need to get spark plugs. I have a built motor and plan to run around 10 or so lbs of boost. stock ignition.
After doing a search i found a crap load of model #'s for ngk plugs, following a 2 step colder theory.
1. ngk bcpr7es-11
2. ngk bkr7e
3. ngk bkr7es-11
4. ngk bkr7es
SOMEONE PLEASE TELL ME WHICH ONE'S TO GET ... I am stuck I would really appreciate the help.
THANKS YOU GUYS, I KNOW U WILL ALL PULL THROUGH AND HELP
Rick
PS if anyone sells them on here, we can talk
1. ngk bcpr7es-11
2. ngk bkr7e
3. ngk bkr7es-11
4. ngk bkr7es
Rick
Re: ngk spark plugs for d16z6 turbo (D21X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X »</TD></TR><TR><TD CLASS="quote">bkr7e i believe the "11" behind the "bkre" means it was pregapped to .044</TD></TR></TABLE>
Correct.
Althought for your greddy turbo app, I would use ZFR6J-11's. See my post here for more info. https://honda-tech.com/zerothread?id=510127
Correct.
Re: ngk spark plugs for d16z6 turbo (ladysman)
Yeah I used the BKR7e-11 on my turbo D16z6. I gapped them to 1.1mm (stock spec). Should I have gapped them smaller???
Also, I went 2 steps smaller just to be on the safe side, and they haven't fouled yet. They're really clean actually.
Re: ngk spark plugs for d16z6 turbo (racinskittle)
We just run NGK BKRE7-11's on our turbo motors ... Depends on the boost and I don't really know for your Z6 but we generally bring the gap down to anywhere from .024-0.30"... Just my $0.02... Peace
Re: ngk spark plugs for d16z6 turbo (Kataku2K3)
thank you guys very much for the help!!! so far so good, turbo install is going very well dropping off my oil pan today to get fitting welded on. I will have boost!!!!!
if anyone hes more help for me, bring it!!! Thanks you guys!!
so i guess i am gonna go with ngk bkr7e plugs
If anyone has any final suggestions, go for it!!
i guess they r the same as bkr7es plugs, unless someone can tell me the difference
Re: (racinskittle)
i ran bcpr7es gapped at what htey came at (.032), never had a problem pop, or miss
Modified by BoostedED9 at 6:16 PM 10/16/2003
