What can be done about torque steer?
Old Oct 13, 2003 | 04:30 PM
BoostedGSRBubble's Avatar
Default What can be done about torque steer?
My cx dosent have ps and at full acceleration its a handfull to drive. It pulls violently to whichever side the road slopes. Im only at 300/220 now and ill be lookin for 400+ next spring. Are there any tricks/mods to reduce the cars yanking, im going to break a wrist.
Old Oct 13, 2003 | 04:35 PM
TurboJesse
Guest
Posts: n/a
Default Re: What can be done about torque steer? (BoostedGSRBubble)
Maybe LSD or traction bars? Not sure...i also have the same problem
Old Oct 13, 2003 | 05:09 PM
Foozball26's Avatar
Default Re: What can be done about torque steer? (Mpir3)
get an alignment
Old Oct 13, 2003 | 05:19 PM
boostsohfast's Avatar
Default Re: What can be done about torque steer? (Foozball26)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foozball26 &raquo;</TD></TR><TR><TD CLASS="quote">get an alignment</TD></TR></TABLE>
exactly
Old Oct 13, 2003 | 05:23 PM
B94Cast's Avatar
Replace that nice turbo setup with an HF motor... and get better gas mileage!!
Seriously though, what about this:
coupled with an LSD. From what I remember, torque steer is caused by both fluctuation in the suspension components, combined with one wheel getting more power than the other (assuming alignment is correct). These two together should substantially limit, if not negate the effects of this. Also Energy Suspension urethane would add to this stability.
My 2 coppers tossed in anyways.
Old Oct 13, 2003 | 05:25 PM
Tinker219's Avatar
Default Re: What can be done about torque steer? (B94Cast)
start wankin w/the other hand, so that both arms are just as strong
Old Oct 13, 2003 | 05:45 PM
grndcont's Avatar
it has to do with your caster adjustment, but u should be able to dial it out to some extent.
Old Oct 13, 2003 | 06:09 PM
SiRex91's Avatar
Default Re: (grndcont)
A good LSD like a Quaife helps a lot. Try and alignment first because it's a lot cheaper than an LSD.
Old Oct 13, 2003 | 06:48 PM
Default Re: (SiRex91)
I have an lsd and jimfabs, i havent had an alignment in a while tho. Ill try it, thanks.
Mr.Death
Jul 28, 2005 10:51 AM
ITR1078
12
Apr 13, 2005 09:05 PM
pkt1213
Jan 30, 2005 01:04 AM
otakueric
May 23, 2004 05:33 PM
CA6VTEC
Mar 4, 2004 12:01 AM
