Fluctuating RPM problem
Old Oct 14, 2003 | 03:30 PM
luti's Avatar
Default Fluctuating RPM problem
I have been having a weird issue with my RPM's lately. When I hold the car at a specific RPM in neutral the RPM will jump up and down about 500rpms. When I drive it and hold it at a specific RPM it will sort of stutter. I looked for vacuum leaks but couldnt find any, I'll check again. I've also noticed that with the car off but the key in 1 click the VAFC reads -26 vacuum. Is my map sensor bad? Anyone care to comment?
Old Oct 15, 2003 | 11:56 AM
luti's Avatar
Default Re: Fluctuating RPM problem (luti)
bump
Old Oct 15, 2003 | 02:22 PM
m3bluegsr's Avatar
check your iac sensor, clean it out with brake clean, then see if it still does it.
Old Oct 15, 2003 | 04:01 PM
ScottEK's Avatar
Default Re: Fluctuating RPM problem (m3bluegsr)
Mine used to do this same thing, I dont know if it matters but I have my throttle body skipped for the coolant line path. I would stage and hold my RPMs at 3000 and about every 3 seconds the RPMs would drop to 2500 or so. It would just repeat that over and over.
Old Oct 22, 2003 | 04:17 PM
luti's Avatar
Default Re: Fluctuating RPM problem (beta13)
What did you do to fix the problem?
Old Oct 22, 2003 | 05:09 PM
ScottEK's Avatar
It just went away one day, sorry.
Old Oct 22, 2003 | 05:51 PM
luti's Avatar
damn, I wish mine would do that.
Old Oct 22, 2003 | 06:08 PM
turbonitrousgsr's Avatar
I have the same problem ever since I got my JG manifold and throttle body. The check engine light would come on for the IAC and my car idle would jump about 600 or so and sound like a damn heartbeat and would jerk when I pushed the gas. I have to reset the ecu every now and then to make it stop. I have never heard of cleaning it though. Does anyone have any other solutions to this problem?
Old Oct 22, 2003 | 07:13 PM
HybridKOOP's Avatar
Default Re: Fluctuating RPM problem (alternativeGSR1)
Check your crank angle sensor and plug...
Old Oct 23, 2003 | 07:15 AM
luti's Avatar
Default Re: Fluctuating RPM problem (HybridKOOP)
How would I check/test this? Any help please, this problem is driving me nuts.
GsRrrr
Aug 15, 2011 11:04 AM
19992civichatch
Mar 15, 2007 07:33 PM
redpeppers
Jul 26, 2005 05:10 AM
