some ?'s about headwork and fi engines
Old Oct 14, 2003 | 06:04 PM
boosted_dc2's Avatar
Default some ?'s about headwork and fi engines
as some of you know i will be doing a rebuild over the winter. i have some questions on heads. I heard that its wasted money with FI...is this true? im refering to a P&P with titanium valvetrain (to rev out to 9500). Also what is the difference between a 3 angle and 5 angle valvejob. what does it mean???
thanks
Landon
Old Oct 14, 2003 | 06:14 PM
intekragsr's Avatar
Default Re: some ?'s about headwork and fi engines (boosted_dc2)
Keep it stock. Many people with 350+ whp with a stock head.
Old Oct 14, 2003 | 06:19 PM
Jared's Avatar
The angle of the valve job is how many anges are used to cut the seat to achieve a perfect seal with the back of the valve, imo any more than 3 is excessive, and sometimes uneccesary except in big race applications, most cases the typical 45 degree cut on the valve back and seat work just as well. How much hp are you planning to make with this engine? That will dicate what you do to the head.
Old Oct 14, 2003 | 06:24 PM
Jared's Avatar
btw, go here for valvetrain: http://www.ef-1.com/
Old Oct 14, 2003 | 07:49 PM
Ricey McRicerton's Avatar
Default Re: some ?'s about headwork and fi engines (Jared)
I'd suggest the valvetrain...turbos love revs. Other than that, unless this is a race application, Id keep the head stock.
Old Oct 14, 2003 | 08:02 PM
psi420's Avatar
I vote stock!
Old Oct 14, 2003 | 08:27 PM
trbob16a's Avatar
Default Re: (psi420)
I have a fully worked head by DPR.
Keep it stock, it isn't worth it. Definitely upgrade your valve springs though, 8k comes way too fast in a turbo b series. Most turbo b series will make good power up to 9k even on stock cams.
Old Oct 14, 2003 | 09:22 PM
Default Re: (trbob16a)
thanks for the replies guys so much help, im planning on having 350 whp.
Landon
Suzukii
Dec 23, 2005 10:35 AM
bukbukintegra
Nov 16, 2005 01:14 AM
ScottEK
Dec 3, 2004 12:55 PM
gimpykid
Aug 5, 2004 05:42 AM
98R #448
May 7, 2002 12:46 PM
