Would I need a Wideband 02 to tune my car with uberdata?
Just as the topic says, wanting to know whats the cheaper route.. v/afc hack, fmu, or ubderdata/hondata and such, so far uberdata is not too expensive at all only for the fact that i might need a wideband o2 sensor.. is it 100% necessary to have it? thanks in advance H-T genuises.
Re: (evilcivilian)
You could use a pyrometer and the stock O2 sensor, but that's not really realiable. Why not just get the uberdata and pay some to dyno tune it?
Re: (brryder)
windband isn't any more nec. than with fmu, or afc hack... But you shouldn't drive a car that hasn't been tuned no matter what you use to add fuel to it. People blow up cars because they cut corners with tuning. I bet more than half of the turbo hondas blow due to lean condition. I bought a wideband so I can keep an eye on it. But you could just take your car into the dyno when your done and check it that way. But personally i would rather have the option to keep an eye on it all the time.
Re: (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote"> I bought a wideband so I can keep an eye on it. But you could just take your car into the dyno when your done and check it that way. But personally i would rather have the option to keep an eye on it all the time.</TD></TR></TABLE>
Same here.
Same here.
I could have had my turbo installed and tuned 2 months ago, and I have been working on putting the kit together for over a year. But I decided to wait so that I could get the wideband o2 inorder to keep and eye on a/f.
Re: (kender)
This is the exactly why I bought my wideband before any of my turbo parts. That way I won't be tempted to boost my car on a untuned map.
My suggestion wait till you get your wideband.
Re: (oxSLEEPERxo)
Ive had ran Uberdata's basemap on my GSR for 1-2 months.. And no problem, only the fact that it had 10-13 MPG on gas. lol...
Was stupid for me to run it untuned, yet the motor held fine... 200 compression all across....! after few months...
Then finally, i bought myself wideband not to long ago... Boy was I NUTS!!
Heres what my wideband read on avg:
IDLE: 11:1 <---VERY DAMN RICH for IDLE!!
when in boost..: *(3,500rpm - 8,100rpm) It ranged from 12:1 AFR to 13.5:1 AFR! O_O LOTS OF POWER! yet... 13.5AFR was pretty damn lean.. if u ask me.. around 8000 rpm. =P
All and all, get a wideband! or get it tuned~ It will save you money on gas / headaches / blown motor, in the long run .... Trust me... You will lose more on paying for gas... So do it right the first time.
Re: (synik)
It's not absolutelty necessary, AT FIRST. You can run a good UD base map and do a little street tuning to make sure you get your car running smoothly. THEN, when you have enough money get tuned with a wb02 or buy your own. That's if you're really stressed for $$$. If you think about it though, a wb02 is a lot cheaper than having to rebuild a blown engine.
See my sig, there is a nice sub $300 wideband on groupbuy special from one of the HT sponsors.
Re: (kender)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kender »</TD></TR><TR><TD CLASS="quote">I could have had my turbo installed and tuned 2 months ago, and I have been working on putting the kit together for over a year. But I decided to wait so that I could get the wideband o2 inorder to keep and eye on a/f.</TD></TR></TABLE>
definately a good way to do it. you might be able to make a rich *** basemap with the uberdata, and drive the car around on really low boost settings for a lil while until you can get to a dyno or a wideband, but i wouldnt push it much
elpiar
03-18-2005 01:05 AM
Westrock2000
02-25-2002 05:20 PM
