GE fuel rail
Old Sep 30, 2004 | 07:56 PM
Dee's Avatar
Dee
Default GE fuel rail
Ok peeps.. I am trying to put some boost back into my life but I keep sunning into problems. Who here runs a GE fuel rail with AN fitting adapters? It looks like my -4 to 18mm 1.5pitch adapters might cause come cavitation problems. Has anybody experienced any problems?
I do not want to weld the fittings to the rail so I plan to trim the nipple off (about 12mm) of each fitting. Hopefully this willl work. If you look at the blurry 2nd pic you will see how the nipple on the fitting almost covers the inlet for the end injectors. I need to get this **** fixed because I have been driving a 660cc K-truck that is geared like a tractor.
I know somebody is going at ask... I can not find the OEM fitting and plug for the rail because I bought this thing more than a year ago and I had planned to use AN fittings for the very beginning.
Modified by Dee at 12:09 AM 10/1/2004
Old Sep 30, 2004 | 08:12 PM
m R g S r's Avatar
Default Re: GE fuel rail (Dee)
Why is that nipple there, what does it do?
Old Sep 30, 2004 | 08:21 PM
Dee's Avatar
Dee
Default Re: GE fuel rail (m R g S r)
The adapter fittings are some weird *** power steering adapters. If I remember correctly the threads on the GE barb fitting were really short. Maybe only 4 or 5 threads deep. These AN fittings seal with an O-ring so hopefully I will not have any problems.
Old Sep 30, 2004 | 08:27 PM
m R g S r's Avatar
You can't buy different ones?
Old Sep 30, 2004 | 09:08 PM
Full-Race Geoff's Avatar
why not just tap it to an NPT and you can use a normal fitting
Old Oct 1, 2004 | 01:29 AM
Dee's Avatar
Dee
Default Re: GE fuel rail (Full-Race Geoff)
problem solved... I use an air powered saw to hack off the needed 12mm.
Geoff... did you forget where I live? metric stuff is easier to locate.
Old Oct 1, 2004 | 06:57 AM
Flamenco-T's Avatar
How old is your GE rail ?
The new ones uses -8AN O-ring boss thread.
stan
Old Oct 1, 2004 | 07:10 AM
Dee's Avatar
Dee
Default Re: GE fuel rail (Flamenco-T)
Stan.... it's a bout a year old but I can also use -8 lines if I get the -8 to 18mm adapter. My setup uses -6 and I see no need to go with -8. Street + "less than" 1/8mile track on an island that is 60 miles long from top to bottom = no need for outrageous HP.
johnwohl
Feb 10, 2008 11:07 AM
HpRevolution
May 23, 2007 09:42 AM
sleepyhatch00
Sep 23, 2005 12:19 PM
rjardy
Oct 21, 2003 10:32 PM
