280zx turbo information?
Old Oct 4, 2004 | 12:08 AM
s1ngle's Avatar
Default 280zx turbo information?
As the topic says, i'm looking at buying one and would like to know what the specs on it are. anyone know of any site that might list it?
Been looking around a lot to no avail.
Thanks!
Old Oct 4, 2004 | 05:03 AM
s1ngle's Avatar
Default Re: 280zx turbo information? (s1ngle)
bump, help my current turbo is spraying oil.
Old Oct 4, 2004 | 05:04 AM
BROOD's Avatar
The 1982 280ZX turbo had a Garrett T3 Turbo (60 comp trim and .63 turbine trim, I believe). It has the Nissan/Mercedes turbine housing so if you plan to run an external WG the regualr Ford 5 bolt flange will not fit.
Eden Prairie, huh I spend three weeks up there doing cold start testing.
Old Oct 4, 2004 | 05:16 AM
BROOD's Avatar
Old Oct 4, 2004 | 08:22 AM
s1ngle's Avatar
Default Re: 280zx turbo information? (BROOD)
so do you mean the normal T3 5 bolt flange will not fit on this turbo?
yessir, cold eden prairie. What do you mean you did cold start testing here? who do you work for?
Old Oct 4, 2004 | 11:07 AM
BROOD's Avatar
Yes, the turbo uses a different turbine housing than the Ford/Turbonetics one. The more common T3 5 bolt flange will not bolt to this housing...the bolt pattern is too small on the flange.
~If your using the internal WG portion you already will have the 5bolt flange (as the WG flapper is built into this flange) and will need the three bolt DP flange instead.
~If you are planning on an external WG, you will need to find a proper flange. Regaurdless if you are mounting the WG on the manifold or on the turbine flange.
This turbine housing is sometimes called Nissan, Mercedes, AMG, and possibly another type of housing.
Well it was not cold In Eden Prairie at the time I was there, but it was cold in the testing cell. Nice place.....I liked Baker's BBQ
Old Oct 4, 2004 | 01:57 PM
s1ngle's Avatar
is there a nice comprehensive turbo specification website that you use?
My_EFsedan
Sep 27, 2011 10:15 PM
503_EF9
Nov 13, 2008 11:17 PM
JD95hatch
Oct 14, 2004 01:23 PM
fjt
Aug 24, 2004 10:50 AM
