How do you use wideband o2?
Old Oct 4, 2004 | 01:55 PM
evilcivilian's Avatar
Default How do you use wideband o2?
As the topic says, say im going to tune my own ecu with uberdata and doing all the right things with injectors (450 dsm) and getting wideband o2 sensor, now how do i use it.. say im running lean, and want to make it rich, do i adjust the wideband o2 sensor or do i adjust more rich conditions in uberdata.. if so how do i do that? thanks all help is appreciated you turbo gurus
Old Oct 4, 2004 | 01:57 PM
93turbo16's Avatar
You adjust your Fuel map. You can't adjust fuel with a wideband, all that does it read the mixture. Take it somewhere and let them do it first. THen play with it.
Old Oct 4, 2004 | 02:46 PM
Nikoli's Avatar
Default Re: (93turbo16)
unless you feel fully confident or have some spare engines lying around i wouldnt tune it yourself
Old Oct 4, 2004 | 02:49 PM
why not?? people have lots of success stories, you're one mean person
Old Oct 4, 2004 | 02:52 PM
Insane's Avatar
Default Re: (evilcivilian)
No hes not hes just giving you good advise
Old Oct 4, 2004 | 02:53 PM
Nikoli's Avatar
how was that mean? lighten up buddy
all i am saying is that you will mess your engine up if you dont know what you are doing
Old Oct 4, 2004 | 04:27 PM
hondaguyef's Avatar
Default Re: (Deckedlude)
Hit up the Uberdata forums. There is lots of good info there. You will need to make a basemap and tune from there. Go to the uber forums like I said and you will see.
Phil
Old Oct 4, 2004 | 04:53 PM
EJ1 wilcox's Avatar
Default Re: (hondaguyef)
You can tune it yourself if you have a wideband...
Just do a lot of research before you do, and make sure you know how to adjust the maps in uberdata...
If you have a good basemap and slowly build up to full boost tuning bit by bit making sure your a/f ratios are good... you should be golden...
Just make sure you know how to use the software and the burner etc... datalogging is really the way to go if you want to install a logging cable into your ecu. That way you can see your ratios after a pull and adjust accordingly...
Read Keebler's write up on uberdata tuning, you can find it in the uberdata forum, that should get you going... good luck
Oh, don't be intimidated, you can figure it out!
Old Oct 4, 2004 | 05:10 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">unless you feel fully confident or have some spare engines lying around i wouldnt tune it yourself</TD></TR></TABLE>
I'm going to have to agree with this guy at this point. If you are asking how to use a WB to tune your car, than its obvious you don't know anything about tuning a car's ECU and should should not start making ECU maps to test and run on your motor to learn how to tune. Do a lot more research and reading up on the Uberdata forum, Hondata Website/Forum, and AEM forums to understand what goes into tuning a car via ECU modification.
Old Oct 5, 2004 | 09:50 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilcivilian &raquo;</TD></TR><TR><TD CLASS="quote">why not?? people have lots of success stories, you're one mean person</TD></TR></TABLE>
Not mean - just realistic. We all would hate to see an enthusiast blow up there motor and from your post, it seems you would.
Do you actually have the means to make changes to Uberdata - a laptop, burner, etc...?
Old Oct 5, 2004 | 09:53 AM
PM-Performance's Avatar
Default Re: How do you use wideband o2? (evilcivilian)
if you have to ask that, i reccomend not trying to do the tuning yourself.
Old Oct 5, 2004 | 10:52 AM
thanks for the responses guys, have all that i need to hear
redej878
May 22, 2006 12:18 PM
mdixonjam
Jul 13, 2005 09:53 PM
TheHatchHog
Oct 12, 2004 07:18 AM
turbo Si
Mar 10, 2003 02:56 PM
liam821
Feb 8, 2002 11:31 AM
