Noob FI Question on Vacuum Lines
Old Oct 4, 2004 | 06:52 PM
Guam_CiviC619's Avatar
Default Noob FI Question on Vacuum Lines
I've always wondered what happens to vacuum lines on a boosted motor? Like the brake booster, PCV, etc... Don't these lines get pressurized under boost? If so how do you get them to function?
Forgive my noobness.
Old Oct 5, 2004 | 01:50 PM
Default Re: Noob FI Question on Vacuum Lines (Guam_CiviC619)
bump for education
Old Oct 5, 2004 | 09:08 PM
Slobnobbers's Avatar
I'd like to get some feed back on this too. When I was building my Nissan motor for my L6T 280Z I needed a motorized vacuum pump... is this thing still needed? What has every found to be the case?
~Nic
Old Oct 5, 2004 | 09:35 PM
f22b2tdave's Avatar
Default Re: Noob FI Question on Vacuum Lines (Slobnobbers)
oh wow, I never really thought about that. How would the brake booster and such stock vacuum-run/enabled devices take to positive pressure? Does it still do the same thing, or any benefits/problems?
edit, pcv needs to be re-thought i know that much, im running both my vent lines from the crankcase into a baffled can and then into a bung on the exhaust through a check valve.
but how does the brake boosters check valve still work?? I dont understand that.
Old Oct 6, 2004 | 02:35 PM
Bump for anti-ignorance
Old Oct 7, 2004 | 03:26 PM
Bump for an answer
Old Oct 7, 2004 | 03:35 PM
Bailhatch's Avatar
The stock brake booster has a one-way valve in the line so it won't see any boost.
The fuel pressure regulator works fine for boost and continues it's 1:1 pressure rise.
Evap purge is only actuated at certain times which I assume is somewhere in vacuum and low throttle.
The map sensor also can work as long as the voltage output is limited to keep the ecu happy (like in the hack or using a missing link). It's usable to around 11psi.
cruise control. i just know that it still works. It's weird when you fall asleep and the bov wakes you up at the top of a hill....i bet.
Old Oct 7, 2004 | 05:53 PM
RyanEJ8's Avatar
Default Re: Noob FI Question on Vacuum Lines (Bailhatch)
That's interesting that the cruise control still works.
From my understanding the brake booster will work fine, unless you try breaking with your left foot while at WOT and boosting. Normally you would let off the gas and then brake, therefore the engine and brake booster would be in vacuum.
Old Oct 7, 2004 | 06:07 PM
Bailhatch's Avatar
Default Re: Noob FI Question on Vacuum Lines (RyanCivic2000)
I left foot brake mine while i'm somewhere between 0-5psi. never noticed it feel any different but I'm not exactly romping on the brake either. I think you will have some vac assist at first but then it would taper off (assuming your boosting at the time)
I actually don't have cruise myself but I have done a Z6 and an H22 and they both say it works and is kinda funny on hilly roads.
Old Oct 8, 2004 | 12:34 AM
Cool thanks for the info.
Old Oct 8, 2004 | 05:31 AM
IN VTEC's Avatar
The brake booster has a bit of a reservoir for vacuum. Ever notice when you remove the booster line it sucks air in for a few seconds.
Old Oct 8, 2004 | 11:19 AM
Default Re: Noob FI Question on Vacuum Lines (IN VTEC)
Yeah, it is designed as a saftey feature to give you one.. maybe two good pumps before your brake assits runs out. It is for "emergency" use if the motor dies while driving.
Reading these posts reminded me the vac pump on the Datsun was for the vac controls of the climate control. I gues Honda's are combo electric/mechanical?.?.?...
That cured my woes...
Thankx all.
~N
slamLOWnBANGIN
11
Feb 19, 2010 03:55 AM
RED95EG6
Jun 9, 2008 02:47 PM
EgSalad
Jul 19, 2006 08:41 PM
nd8ch
Jan 12, 2004 11:12 PM
disguy409
Jun 30, 2003 03:16 PM
