what to use when cutting oil return line
Old Oct 3, 2004 | 03:56 PM
careawholelot's Avatar
Default what to use when cutting oil return line
what are u guys using to cut the oil return line to make it smaller, would a good ol razor do the trick
Old Oct 3, 2004 | 04:08 PM
toolowsol's Avatar
Default Re: what to use when cutting oil return line (careawholelot)
i wrapped it in electrical tape, then went at it with a hack saw
Old Oct 3, 2004 | 04:11 PM
Default Re: what to use when cutting oil return line (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol &raquo;</TD></TR><TR><TD CLASS="quote">i wrapped it in electrical tape, then went at it with a hack saw </TD></TR></TABLE>
hmmm looks like this is what i'm gonna do, anyone else
Old Oct 3, 2004 | 04:19 PM
5thgencivic's Avatar
I used a big pair of bolt cutters.
Old Oct 3, 2004 | 04:25 PM
IN VTEC's Avatar
Default Re: what to use when cutting oil return line (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">I used a big pair of bolt cutters.</TD></TR></TABLE>
That's what we use. Almost a perfect cut every time. I rarely ever worry about getting into a fight with steel braided line anymore.
Old Oct 3, 2004 | 04:31 PM
i'm gonna do this
Old Oct 3, 2004 | 05:14 PM
Bailhatch's Avatar
I wrap it in e-tape and use a diegrinder with cutoff wheel. Works mint as long as you go slow so you don't melt the liner. Doesn't suffer from the tearout like a hacksaw can.
Old Oct 3, 2004 | 05:16 PM
Mase's Avatar
Default Re: what to use when cutting oil return line (Bailhatch)
dremel works fine too, just use tape.
Old Oct 3, 2004 | 05:30 PM
turboteg2nv's Avatar
Default Re: what to use when cutting oil return line (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">dremel works fine too, just use tape. </TD></TR></TABLE>
Ditto, electrical tape and dremel cut-off wheel
Old Oct 3, 2004 | 05:45 PM
IN VTEC's Avatar
Default Re: what to use when cutting oil return line (turboteg2nv)
I betcha my bolt cutters are faster than your cut-off wheel. Not trying to brag or anything.
Old Oct 3, 2004 | 07:34 PM
B18C1CYA's Avatar
tape it up and use a chop saw, just go slow,
88crxhfb16
Jun 27, 2005 08:53 AM
civicek00
May 31, 2005 09:38 AM
turboH22Aakkord
Apr 14, 2005 11:55 AM
FOrSfEd
May 21, 2004 03:39 PM
D A 9
Jul 27, 2003 05:16 AM
