just did a compression test......
Old Oct 3, 2004 | 11:26 AM
Nikoli's Avatar
Default just did a compression test......
i just did a comp. test yesterday and it read 208 across the board. what does that mean my compression is? somewhere around 10:1 maybe?
Old Oct 3, 2004 | 11:53 AM
StolenTeg's Avatar
Default Re: just did a compression test...... (Deckedlude)
I dont think you can tell the compression ratio basing on the compression of your cylinder, i could be wrong tho...
Old Oct 3, 2004 | 02:13 PM
XxRoCkMaNxNEOxX's Avatar
Default Re: just did a compression test...... (StolenTeg)
i say as long its all good across the board its ok. i have a b16 and it read about 207 so it should be ok
Old Oct 3, 2004 | 02:15 PM
crxY-49's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg &raquo;</TD></TR><TR><TD CLASS="quote">I dont think you can tell the compression ratio basing on the compression of your cylinder, i could be wrong tho...</TD></TR></TABLE>
You can find the actual compression ratio by doing a compression check...forgot the conversions though.
Old Oct 3, 2004 | 02:19 PM
Mase's Avatar
depending on the gauge, my gauge will read 200-210 or so for 9:1.
your compression is most likely 9:1
Old Oct 3, 2004 | 02:22 PM
SEFIxCivic's Avatar
Default Re: just did a compression test...... (Mase)
mase, whats 225-230 on a 1.8 gsr equal compression wise?
Old Oct 3, 2004 | 02:27 PM
Mase's Avatar
Default Re: just did a compression test...... (SEFIxCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEFIxCivic &raquo;</TD></TR><TR><TD CLASS="quote">mase, whats 225-230 on a 1.8 gsr equal compression wise?</TD></TR></TABLE>
it really depends on the type of compression gauge. but if a car read around 230 on my gauge, it woudl be close to 10:1
Old Oct 3, 2004 | 02:33 PM
SEFIxCivic's Avatar
on two different gauges, craftsman and then snap on. thanks tho.
dc4teg95
Nov 6, 2007 04:18 AM
Combustion Contraption
53
Nov 18, 2006 09:50 PM
Mr.Integra
Apr 22, 2004 07:56 PM
Mr.Integra
Apr 22, 2004 07:55 PM
