Tial Wastegate------Need to know what kind of screw, or i'm screwed.
I don't have any screws to connect my tial wg to a dumptube. I can't find any that turn more than two threads, the only ones that fit is the ones I got in the box but i only have the ones to connect to the manifold. Does anyone know exactly what size, thread, bolts I need to get, and where I can get them?
Re: Tial Wastegate------Need to know what kind of screw, or i'm screwed. (silverb18)
this might help
https://honda-tech.com/zerothread?id=373905
http://www.atpturbo.com/Mercha...e=FST
You can opt for the studs/nuts as well, but the ATP nuts don't clear the newer, fatter base on the 38mm TiAL w/g's, so you have to use an OEM exhaust/intake manifold nut. You can also use OEM manifold bolts/studs/nuts for w/g and dumptube connections, as well as DP connections(for most T3's). Same thread: 8mm x 1.25 pitch.
xtrec02
08-10-2008 01:22 PM
boostincoupe
04-12-2006 10:15 PM
