turbo newbie - cheap setup
Old Oct 4, 2004 | 11:50 AM
Jon V's Avatar
Default turbo newbie - cheap setup
Well I have been contimplating trying to piece together a cheap turbo kit for my stock D16 in my 99 hatch. Thusfar I have spent most, if not all, of my money on my suspension and i feel my car is now ready, and more than capapble of handling some more power. I plan on doing a swap in the up coming future (6 months- 1yr), but I need some more power befor that.
As I was talking to my friend this weekend about his MR2 that he just got his JDm swap dropped in I realized that he has 2 decent MR2 turbo motors just sitting in his garage. each has there problems, one came out of a car he flipped in the rain but should actually be in pretty good shape, and the other motor just came out of his car and something internally is definetly blown. But both turbo's should still be good. I believe they are GT25's, but I am not to sure about that.
My questions are, minus the cost of the turbo how much am I lookin at spending to piece together a whole kit (hardwear), and the big question what am I going to need as far as tuning, fuel management, Eng management...
I am not asking for an exact price quote, just maybe a reference as to how much you spent on a similar setup. or maybe a small list of things I am going to need and an estimated price..
mani-
down pipe-
intercooler+piping-
BOV-
waste gate-
ect....
As I stated when it comes to boost, I am still a noob so please be gentle and try not to flame to much.
P.S. is the GT25 a decent turbo for my single cam, and is it a commonly used turbo? Will it be hard to find a mani or downpipe with the right flanges?
Old Oct 4, 2004 | 12:13 PM
Jon V's Avatar
Default Re: turbo newbie - cheap setup (Jon V)
come on guys....
Old Oct 4, 2004 | 12:22 PM
Charlie Moua's Avatar
well hum,
honestly your D16 is it the y8?
If it is a gt25 thoes **** are expensive. Before i even start getting the turbo kit together pick the turbo first. If you want to see if you can use the gt25 send it in to test it & make sure it's not blown or what not.
Personally if your looking for a cheap easy turbo setup i would reccomend going the dsm t25 or dsm 14b turbo mated to a civic std exhaust manifold with adapter plate. Fuel managment, (because this is a cheap setup) I would go with either fmu or afc hack to make it simple.
i think you could get a clean, decent turbo kit make for less than $800.
Old Oct 4, 2004 | 12:29 PM
Jon V's Avatar
Default Re: turbo newbie - cheap setup (Charlie Moua)
I believe it is the D16y7, 99DX motor...
the only reason I want to use that turbo is because I can get it really cheap if not free. but I am not sure how well suited that turbo is for my application?
Old Oct 4, 2004 | 12:42 PM
Nikoli's Avatar
you will need:
larger injectors
oil lines
flanges
fitings
mani
dp
ic
ic piping
wg
bov
fmu or some sort fuel mangement
Old Oct 4, 2004 | 01:19 PM
Jon V's Avatar
Default Re: turbo newbie - cheap setup (Deckedlude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">you will need:
larger injectors
oil lines
*flanges for downpipe and mani ?
*fitings for oil lines?
mani
dp
ic
ic piping
wg
bov
Thanks, just trying to make sure I get everything right
does anybody have any advice on the cheapest most reliable fuel managment?
and what exactly does FMU stand fro?
again thankx for being patient and thanks in advance for any help...
Old Oct 4, 2004 | 01:27 PM
Teglove2's Avatar
It stands for fuel management unit. It raises fuel pressure(8 to 12psi) per pound of boost. They are decent set-ups for low boost applications. ****, I've seen fmu/safc hacks turn over 300whp safely. I wouldn't do it but I've seen it done many times. Here's also something to think about. Since you said you're going to get a motor swap, I would definitely buy quality turbo parts for this motor because you will eventually sell that stuff and it will be hard selling low quality stuff, just my opinion. Good luck
Old Oct 4, 2004 | 01:30 PM
Jon V's Avatar
Default Re: (Teglove2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Teglove2 &raquo;</TD></TR><TR><TD CLASS="quote">It stands for fuel management unit. It raises fuel pressure(8 to 12psi) per pound of boost. They are decent set-ups for low boost applications. ****, I've seen fmu/safc hacks turn over 300whp safely. I wouldn't do it but I've seen it done many times. Here's also something to think about. Since you said you're going to get a motor swap, I would definitely buy quality turbo parts for this motor because you will eventually sell that stuff and it will be hard selling low quality stuff, just my opinion. Good luck</TD></TR></TABLE>
alright, thanx.
That might be what i am lookin for since I am not lookin to run alot of boost. I am not planning on doing any internal work and am just lookin for something to slap on, tune, and run reliably for about 6-8 months. how much does an FMU go for?
Old Oct 4, 2004 | 01:35 PM
Jon V's Avatar
Default Re: (Jon V)
any comments on your personal setups and the parts you used would be a good help. I can research and learn some stuff while doing it, I just really don't know where to start. So any advice on specific parts would be helpfull.
Remember cheap and reliable, not lookin for big numbers here just a little extra "boost".
Old Oct 4, 2004 | 02:55 PM
Jon V's Avatar
Default Re: (Jon V)
anybody got any advice on manifolds?
Old Oct 5, 2004 | 04:35 AM
Default Re: (Jon V)
click me..... std/hf
Old Oct 5, 2004 | 12:40 PM
Jon V's Avatar
Default Re: (Charlie Moua)
alright well I just recieved a payment from paypal, and I think I am about ready to get this little turbo project started...
Old Oct 6, 2004 | 05:50 AM
Jon V's Avatar
Default Re: (Jon V)
alright update, the turbo in question that I have is a Toyota CT-26 not a GT-25. It appears to be a smaller sized turbo which is all I need. It did come stock on is 2.0L motor and did a good job, so I am just questioning wheather this particular turbo would be a good choice for a semi low boost single cam application?
Stock block, stock head. lookin to boost 6-8 pounds
OEM 1993 MR2 turbo- Toyota CT-26 turbine
Old Oct 6, 2004 | 06:33 AM
Scean's Avatar
Default Re: (Jon V)
so far ive spent 785 for,
14b turbo, excellent condition no shaft play
ic piping, most of it anyway need a couple small pieces
dsm side mount intercooler
Downpipe
Hf Manifold w/ adapter plate, already mated to turbo
Greddy Type S bov
oil feed and return lines and fittings
uberdata chipping stuff
burner to burn chips for uberdata
soon to come,
boost and a/f gauge 70$ from a guy i know here
Dsm 450cc injectors hopefully about 50$
Bov flange, 20$
miscallenious (sp) 25$
Total, turbo for 950 not to bad i dont think, daily driving at about 8psi w/ good fuel manegment, should be fun
Old Oct 6, 2004 | 06:34 AM
Scean's Avatar
Default Re: (blackcivic95)
and to the creator, where are you located, i know of a guy who just blew a turbo mr2 motor, you in or around Newnan, Ga??
Old Oct 6, 2004 | 06:39 AM
Jon V's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcivic95 &raquo;</TD></TR><TR><TD CLASS="quote">and to the creator, where are you located, i know of a guy who just blew a turbo mr2 motor, you in or around Newnan, Ga??</TD></TR></TABLE>
Nope, born and raised in Cali...
The guy I know blows them up all the time. J/K
How much did you pay for your turbo if you don't mind me asking?
Old Oct 6, 2004 | 06:42 AM
Scean's Avatar
Default Re: (Jon V)
nah dont mind, actually i got a deal, got the
turbo w/ oil fittings on it
oil lines w/ brass tee for back of block
downpipe
side mount ic
and the ic pipes all for 550 shipped to my door
Old Oct 6, 2004 | 06:52 AM
Scean's Avatar
dont think the guy wasnt to smart sellin it to me, the turbo had just "had a rebuild" supposedly 500 miles before it was pulled off the car, i was like sure whatever cuz i didnt think it was true but even for that price if I have to put a lil money into the turbo i still come out good, but nope perfect cond. shaft wont move in any directoin no matter how hard i try, the oil seals are still to be seen tho, hopefully there good to
Old Oct 6, 2004 | 06:58 AM
Scean's Avatar
just be patient and look around the classifieds on the different forums, h-t, turbo d16, hmt, etc, and look around ebay too, youll find a deal
preludefan
Dec 21, 2008 10:06 PM
dazcivic
Aug 15, 2007 10:59 AM
Smoke_Screen_Civic
34
Jan 23, 2004 06:55 PM
TurboEg
Aug 1, 2003 06:46 PM
