What's the thread pitch for this oil feed on?
TSPeed Factory
What's the thread pitch for this oil feed?
its a T3/T4e if that helps. so far i put a male -3AN and a 1/8 NPT in there and they both seem to fit the same, but i want the correct fitting for it.
i checked Flamenco-T's thread and it didn't state it.
TSPeed Factory
Re: What's the thread pitch for this oil feed? (Bailhatch)
are you guys positive? because i'm trying to screw in a 1/8NPT and it doesn't even go in all the way. it gets stuck like halfway through.
Re: What's the thread pitch for this oil feed? (AzntaggeR)
pipe thread is tapered, so as you tighten it is gets tighter. Usually you can only get it in like 5 or 6 turns. your all set. just don't overtighten it or it will strip.
TSPeed Factory
ok i'll just thread in the 1/8" NPT then. maybe i'll use teflon tape too, but i just hear stories of it getting sucked through the system and then clogging a line.
start the tape a few threads up or use the paste type of white pipe sealant. Or you can use RTV silicone sealant/adhesive.
blowncivichb
05-11-2002 08:01 PM
