turboedit timing
Old Oct 3, 2004 | 09:29 PM
mattcalica's Avatar
Default turboedit timing
right now i am running 9psi on a first gen b16. I am using the safc hack and my car is running perfect. PLX wideband showing 12.5 afr throughout boost and no detonation issues. I wanted to get a 2 or 3 bar map and up the boost to 15 psi. I know with the hack, it will advance the timing quite a bit in boost, so i wanted to recurve the timing map on turboedit. the basemap for the pr3, though, does not have a boost retard option, so i will have to reconfigure the maps manually. how much timing should i take out to run 15psi safely?
Old Oct 3, 2004 | 11:02 PM
mattcalica's Avatar
Default Re: turboedit timing (mattcalica)
wheres j. davis...i know he would know...
Old Oct 4, 2004 | 05:26 AM
mattcalica's Avatar
bump, before i go to sleep...cmon, any advice guys?
Old Oct 4, 2004 | 06:48 AM
USDM 4G VTEC's Avatar
u might be able to get away with making a normal basemap based on xenocrons writeup
just have the VAFC control ur VTEC point
and use that to go for now
Old Oct 4, 2004 | 07:17 AM
mattcalica's Avatar
um, do you have a link to this writeup?
Old Oct 4, 2004 | 09:48 AM
xenocron's Avatar
Default Re: (mattcalica)
http://www.xenocron.com/te
Right now there isnt enough testing done on the 2-3bar maps right now to recommend you go try that with TE. You can certainly help test though...
You can play with the timing in the stock PR3 maps however you'll be retarding timing while you are in the vacuum ranges which will hurt driveability.
It's a toss-up...you are running a PR3 ecu too and in order to follow my write-up and use the PGMFI code you would need to run it in a PM6/PS9 ECU
93civciv
Dec 4, 2007 05:23 PM
fast2camciv
Sep 1, 2006 06:56 PM
MintFlavored
Apr 22, 2004 02:59 AM
willyboyK20
Oct 30, 2002 09:50 PM
JRSCCivic98
Jun 12, 2002 07:44 PM
