Turbo kit for a B20
Old Oct 3, 2004 | 08:48 AM
2kaccord's Avatar
Default Turbo kit for a B20
Anyone know where to get a turbo kit for a B20? Its in a 93 civic coupe. It has a B20 with a b18 head and a type r tranny. Please let me know if there are any sites where you can buy a complete turbo kit.
Old Oct 3, 2004 | 09:39 AM
JDMs1eeper's Avatar
Default Re: Turbo kit for a B20 (2kaccord)
Search and learn to put one together. Or i'll sell you one.
how big ya want the turbo. t3? Big T3 60trim , T304e? t3/60-1, t4/60-1.... maybe bigger? you need to find out what would work best for your goals. Then you can make it happen from there.
Old Oct 3, 2004 | 10:11 AM
beerbongskickass's Avatar
Default Re: Turbo kit for a B20 (JDM S1eeper)
Build your own turbo kit man. I would get yourself an LS block though since your going turbo. B20 sleeves = poo poo.
Old Oct 3, 2004 | 11:22 AM
Blaze45's Avatar
Brrraaaap!
Default Re: Turbo kit for a B20 (beerbongskickass)
Talk to b20turboic about B20 sleeves being "poo-poo". Hes running 15psi daily with Zdyne and isnt having any problems.
Blaze
Old Oct 3, 2004 | 05:38 PM
leed's Avatar
Default Re: Turbo kit for a B20 (Blaze45)
Wow, 15psi. Hes doing something right, or it doesnt get beat on alot.
Just had a friends b20-vtec crack sleaves on only 10psi. This was on 4th gear pull.
Fuel was spot on, and timing was very conservative as well.
Old Oct 4, 2004 | 06:47 AM
Power Rev Racing's Avatar
Default Re: Turbo kit for a B20 (leed)
I know of 2 people running a B20 vtec setup on boost at 10lbs. Both of them are still running and are using a Block Guard.
I would just use a LS block to feel on the safe side though.
Old Oct 4, 2004 | 10:38 AM
Default Re: Turbo kit for a B20 (Power Rev Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">I know of 2 people running a B20 vtec setup on boost at 10lbs. Both of them are still running and are using a Block Guard.
I would just use a LS block to feel on the safe side though.</TD></TR></TABLE>
Exactly. I'm sure people have boosted B20's without problems, but it's not worth it if you ask me. You way better off going with an LS bottom end, just to be safe. The sleeve design of the B20 is crap.
T9U4ReBgO
Nov 16, 2007 07:02 PM
Scantron
Mar 17, 2006 02:32 PM
GoCarInteg
Jul 28, 2005 06:30 AM
blufke
Oct 15, 2002 09:07 AM
