how much power can a stock clutch hold
so i got a d16z6 turbo and i finally got it out on the road and i noticed the rpms are raising alot faster then the speed, now some people say it is a slipping clutch, but it is a new clutch and flywheel. can the pedal need adjustment? i noticed that the pedal angaged really soon and seems sloppy when it is almost depressed
fyi i am running 8 lbs
B
B
Re: how much power can a stock clutch hold (Btothe3rdDegree)
A stock clutch should be good till about 160-170 whp. I'm running 6 psi on a completely stock clutch with 150k on it and it holds up fine still. For now anyways.
So the clutch was fine right before boost?
Re: (Dr Pooface)
It's gonaa hold about 300whp, but when shifting into the next gear it's probably burn your clutch. I recomend an aftermarket clutch (whether is be a "street disk" or six puck) over 200whp for convienence sake.
Schister66
12-04-2005 02:22 PM
