Gas Mileage with AFC hack?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">I'm just wondering how horribly the AFC hack decreases your gas mileage (out of boost)?</TD></TR></TABLE>
If tuned right it shouldn't. You probably will never know because you will always be in boost.
I used to get about 30 miles to a gallon before then when I got the afchack not beating on it I'd get like 25-27 untuned stock settings(~40 across the board).
My fuel economy has stayed the same with the hack.
My application is a bit different, but if you are still getting 14.5-15.0 AFRs on your wideband while cruising (as you should if you are still OBDII and have it tuned in the right ballpark) then your fuel economy shouldn't suffer.
Of course, my fuel economy goes to **** when I start going into boost often, but usually I am just driving sanely on the freeway.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">I used to get 30+mpg with the hack. still sucked though</TD></TR></TABLE>
my sentiments exactly
