setup almost complete.....now how much power to expect?
Old Oct 2, 2004 | 01:43 PM
elec_blue's Avatar
Default setup almost complete.....now how much power to expect?
I have a 2000 civic Si and I want to know how much power to expect with the
following mods. All the parts are being installed since there is no engine in the car
right now.
Greddy turbo kit with type 31 IC
9:0:1 cp pistons/eagle rods/and benson sleeves
ACL main bearings/ OEM rod bearings/ OEM bottem end gasket kit
Cometic headgasket
walboro 255 fuel pump
AEM fuel rail/ and regulator
AEBS intake manifold/ and hondata intake manifold gasket
GSR camshafts/ Skunk2 valves springs/ skunk2 titanium retainers
NGK 1step colder plugs/ and wires/ and MSD red coil
Hondata s200/ P28 ecu (untuned) have a tunning session on saturday
HKS SSBV
Greddy timing belt/new waterpump/ new miscellaneous bearings and seals
Skunk2 catback exhaust/ hi-flow cat
ARP head studs
RC 720 injectors/OBD1 clips (to be installed at the dyno)
Greddy Profec II boost controller
EXedy organic clutch/ stock flywheel
let me know
Old Oct 2, 2004 | 02:56 PM
94gsr4dr's Avatar
Default Re: setup almost complete.....now how much power to expect? (elec_blue)
To many variables. You aren't going to make much power out of that greddy kit.
Old Oct 2, 2004 | 04:29 PM
elec_blue's Avatar
Default Re: setup almost complete.....now how much power to expect? (94gsr4dr)
Can anybody give some helpful information instead of somebody bashing the greddy kit. I'm looking into getting 300whp and thats it. I wasn't expecting the kit to give me 400+ hp. Anyways keep'em coming
Old Oct 2, 2004 | 05:28 PM
f22b2tdave's Avatar
um...what ****** engine do you have. and you could have hit 300 stock block, maybe not with a greddy kit but still, it seems as if you want more power than that 16g (correct? i dont know) might be able to churn out. why dont you go to the dyno and then they can give you a better estimate (we all know dynos arent 100% accurate) than most people on here probably could. and those people that can tell you on here, are probably out working on their cars. as should i.
rev-speed
Dec 31, 2007 09:04 AM
panda_eh2
40
Nov 20, 2007 10:35 AM
Honda_Fanatic
23
Nov 9, 2007 07:54 AM
tank_99
Jun 9, 2004 06:26 PM
2000Si-at-UK
Apr 10, 2002 09:38 AM
