coolant boiling, please help
Old Oct 2, 2004 | 11:37 AM
integracivic94's Avatar
Default coolant boiling, please help
as title says, just turbo'd a d16z6 for low boost and coolant is boiling so i changed the rad for teg rad and then i changed the head gasket it doesnt overheat but it pushes water out of the expansion tank! somebody suggested it could be a worn water pump any suggestions please!!! at my wits end with this trouble thanks for any help.
Old Oct 2, 2004 | 01:41 PM
xenocron's Avatar
Default Re: coolant boiling, please help (integracivic94)
you change the thermostat?
Old Oct 2, 2004 | 01:42 PM
GDM Z28's Avatar
are you talking about after you drive the car and shut it off you can hear boiling? If so that means your system isn't pressurizing. Same thing happen to me....it ended up being a TINY and i mean TINY hole in a hose. Coolant wouldn't come out but it would pressurize. Id replace the upper and lower radiator hose.....it could also be the radiator cap. Try replacing that too.
Old Oct 3, 2004 | 06:27 AM
Default Re: coolant boiling, please help (civicflnum1)
I will give it a go! gonna try replacing thermostat and rad cap! thanks for the help really appreciate it!
greenlikematt
10
Jul 22, 2008 06:30 PM
Cyber ITR
Sep 25, 2007 03:47 PM
turbohb21
Aug 7, 2007 08:43 PM
Green DC2
Jul 12, 2007 09:42 AM
Accorddrver
Jun 29, 2004 06:25 PM
