Anyone running an oil restrictor on a -3AN oil feed line?
Set up: SC 61 turbo/B18c.
Im replacing my -4AN line with a -3AN line due to oil consumption (oil being pushing passed the turbo seals). Will the -3AN be enough oil restriction alone or should I add the oil restrictor on top of that? The oil restrictor I have is a #72 or #74 NOS jet (I forget which one).
Re: Anyone running an oil restrictor on a -3AN oil feed line? (Turbo Chris)
i have one on mine.. i see 5 psi at idle and it goes over 40 at 4000rpm.. i used a needle valve... i only put one on cause i had a bad turbo before and i was just paranoid.. it only cost me 4 bucks at grainger...-3an feed for me by the way..
Re: Anyone running an oil restrictor on a -3AN oil feed line? (96y7turbo)
I welded my 90 degree nipple on the turbo shut and drilled a small hole through the weld to act as my restrictor.. I forgot what size drill i used, but it's been working great so far.. btw, i'm using a 4AN line ..
I never see any smoke comin out the exhaust, or oil residue in my turbo inlet and turbine outlet...
a must, if you have MINOR oil seal problems...
Re: Anyone running an oil restrictor on a -3AN oil feed line? (92HB_HB)
im having a serious smoking problem now on my car, i have a 4an line, with no restrictor. im gonna convert down to a -3an line, should i run a restrictor as well? im hoping that its not too late, and that i wont have to rebuild the turbo, but we shall see. anyone else have suggestions?
Re: Anyone running an oil restrictor on a -3AN oil feed line? (My95SlvrBlt)
I am running an oil restrictor on my car with an3 line.. Im using an Garret/Airesearch T3..
I had never seen any factory turbo'd engines' oiling systems until a couple nights ago working on a friend's SR20DET. The restrictor is placed in the banjo bolt and the oil feed hard line is probably equivalent to a -4AN line.
We've also had problems on a 3G Eclipse turbo setup when it didn't use a restrictor. It used a -4AN line.
It doesn't help the original poster, but at least it'll throw more info into the general knowledge pool.
South Bay Surfer
07-10-2008 10:31 AM
