Hose clamp hell, need some help please
Old Oct 3, 2004 | 06:11 AM
SuperSteve737's Avatar
Default Hose clamp hell, need some help please
So, for the past 2 weeks, my buddy and I have been going through hell to get his custom turbo setup on his car. First, it was gonna go on a DOHC ZC, but the wastegate wouldn't clear the valve cover, then we swapped in a Z6, and it wouldn't start. So we put in another Z6 and it started.
So now we got everything all good and hooked up, all the hose clamps nice and tight, crank it up, take a cruise around the block, and lose boost. We pull back into his driveway and a hoseclamp came loose. They are just the basic "screw/8mm bolt" deal.
Nothing fancy. So we tighten it up, take another lap around the block, and again, a different hose clamp came loose. What should we be using so the hose clamps stop blowing off? He is putting out about 8psi. TIA.
-Steve
Old Oct 3, 2004 | 06:12 AM
Rod.'s Avatar
Default Re: Hose clamp hell, need some help please (SuperSteve737)
T bolt clamps
Old Oct 3, 2004 | 06:13 AM
drift2004's Avatar
u need heavy duty t clamps
http://cgi.ebay.com/ebaymotors...=6755
something like that
Old Oct 3, 2004 | 06:35 AM
delslowh23's Avatar
Default Re: Hose clamp hell, need some help please (drift2004)
this is where i got mine
https://honda-tech.com/zerothread?id=874025
Old Oct 3, 2004 | 06:43 AM
he has a few of those on now, and they seem to be holding up. I don't know where he got them from, but has anyone ever seen them at Home Depot or anywhere? I tried looking on their sites but couldn't find them. We need to have this up and consistently running, now!!!
Thanks for the quick replies.
Old Oct 3, 2004 | 06:54 AM
BROOD's Avatar
Get the pipe ends beaded. Sometimes just using better clamps is not enough. Sometimes tightening the **** out of the clamps is not the answer either.
Proper beading and good couplers/clamps can hold more pressure than you will ever put in that D series.
Old Oct 3, 2004 | 07:23 AM
oxSLEEPERxo's Avatar
Default Re: Hose clamp hell, need some help please (BROOD)
was he using the clamps on the outside of the silicon hose to connect the pipe?
Old Oct 3, 2004 | 07:35 AM
turboteg2nv's Avatar
Default Re: Hose clamp hell, need some help please (oxSLEEPERxo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BROOD &raquo;</TD></TR><TR><TD CLASS="quote">Get the pipe ends beaded. Sometimes just using better clamps is not enough. Sometimes tightening the **** out of the clamps is not the answer either.
Proper beading and good couplers/clamps can hold more pressure than you will ever put in that D series.</TD></TR></TABLE>
word. get those pipes beaded and grind em down a bit and they should be golden
Old Oct 3, 2004 | 07:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oxSLEEPERxo &raquo;</TD></TR><TR><TD CLASS="quote">was he using the clamps on the outside of the silicon hose to connect the pipe?</TD></TR></TABLE>
Yes, we were.
and we don't know how to weld, so we can't bead them.
Old Oct 3, 2004 | 07:53 AM
BROOD, btw, its' for the motor I bought off of you, from Justin's shed. Stuck in the back of my Impala, remember? LOL, small world.
Old Oct 3, 2004 | 07:59 AM
Sho Pow's Avatar
Most of the pipes are beaded. Im having no problems with those falling off. Just the ones that arent beaded that we used to make it work.
Old Oct 3, 2004 | 08:03 AM
Ri5e's Avatar
Default Re: (SuperSteve737)
You could also find the T bolt clamps at Boating stores but they're like $10 bux each.
Old Oct 3, 2004 | 08:12 AM
Default Re: (JapAndy)
do you have any pictures of your pipe that is beaded?
Old Oct 3, 2004 | 08:40 AM
tspkenneth's Avatar
Default Re: (oxSLEEPERxo)
i suggest going to a near by napa parts store and buying some t bolt clamps..they're like 2-3 bucks a piece... cheapest place i've found
Old Oct 3, 2004 | 08:48 AM
scttydb411's Avatar
make sure you've cleaned any oil residue off the pipes and couplers. rough up the ends of the pipes too.
t clamps will work too.
Old Oct 3, 2004 | 09:22 AM
EM1 MIKE's Avatar
Default Re: Hose clamp hell, need some help please (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">T bolt clamps</TD></TR></TABLE>
Got mine from full-race.
Old Oct 3, 2004 | 03:24 PM
BROOD's Avatar
Indeed it is a small world.
AMS can bead roll those pipes for you, I know they have a Bead roller. I do not know how much they charge though. If not, I'm ordering one next week for my own use......I can bead the pipes for you.
JDM_addict
15
Jun 6, 2010 08:57 PM
SinsEvil666
Sep 7, 2008 03:14 PM
Tippyman
Nov 23, 2006 06:57 PM
mike93eh
May 20, 2005 08:15 PM
confucius
Jan 27, 2002 06:09 PM
