does anyone run this turbo????
Old Oct 3, 2004 | 10:24 AM
B18C1CYA's Avatar
Default does anyone run this turbo????
http://store.yahoo.com/cheaptu....html
I would like to know how it performs for thoses of you that are running it and do you know if it will support 550whp on a 81.5mm gsr ? tia
Old Oct 3, 2004 | 12:00 PM
94gsr4dr's Avatar
Default Re: does anyone run this turbo???? (B18C1CYA)
<U>similar</U> to the full-race t3/67
Old Oct 3, 2004 | 06:13 PM
B18C1CYA's Avatar
Default Re: does anyone run this turbo???? (94gsr4dr)
anyone else?
Old Oct 3, 2004 | 06:18 PM
_entropy's Avatar
I run it. TO4R = T67. Unless the Full-Race turbo uses something like ITS'es inconel wheels or different bearings, the turbos are basically the same. The T67 compressor wheel has supported 700++ RWHP, so I don't think it should have any trouble making 550.
Old Oct 3, 2004 | 06:29 PM
94gsr4dr's Avatar
Default Re: does anyone run this turbo???? (@lbert)
This turbo comes standard with a stage 3 wheel the full race comes with stage 5. I think i remember that full-race did some tinkering with the thrust bearings as well. Other thant that they are the same i believe.
Old Oct 3, 2004 | 06:43 PM
B18C1CYA's Avatar
cool so i guess it will do the job then, o btw how is spool time?
Old Oct 3, 2004 | 09:25 PM
94gsr4dr's Avatar
on my 81.5mm gsr with 9:5 compression i spool the stage 5 wheel t3/t67 at 5200 (10-11psi).
crxtech87
Sep 6, 2013 11:16 PM
BlakeJ53
Mar 9, 2009 09:05 AM
CTGrey06RSX-S
Jan 4, 2008 11:48 AM
Flr Power
Apr 3, 2004 01:33 PM
98civicEX
Jan 1, 2003 06:37 PM
