well just as i thought ...
Old Oct 10, 2004 | 10:47 AM
GReddy SI's Avatar
Default well just as i thought ...
yup it was the ringlands also looks like spun rod bearings?
i will let the pics speak for itself .
Spun rod bearings? btw these are stock block and rods
how does spun rod bearing happen? rod bolts not tighten well?
Old Oct 10, 2004 | 10:48 AM
GReddy SI's Avatar
Default Re: well just as i thought ... (GReddy SI)
btw i was getting white smoke from my valve breather and alot of white smoke when i pushed it hard .
the compression was this
4=85 added a cap of oil and it jumped to 105 (first one pic on the post )
3=210 ( ringland cracked )
2=210 (ringland also had a crack
1=220 (looked good)
Old Oct 10, 2004 | 10:57 AM
Ri5e's Avatar
Looks like worn bearings, not spun. Spun bearings happen when there is too much friction (too little oil or the clearances between the bearings and the rod/crank surfaces are too small) so there is metal to metal contact and the engine will make a loud clicking noise and eventually seizes up and you throw rods and stuff.
And the spun bearings would look dark purple (from the heat of friction).
Modified by TurboSmart at 12:12 PM 10/10/2004
Old Oct 10, 2004 | 10:58 AM
chameleon's Avatar
detonation maybe?
Old Oct 10, 2004 | 11:01 AM
GReddy SI's Avatar
Default Re: well just as i thought ... (chameleon)
well i noticed this white smoke before but i didnt think of it much ,
then went to get tuned and btw with these bad ringlands
i still got 225hp 161tq lol 7psi
Old Oct 10, 2004 | 11:06 AM
chameleon's Avatar
yeah white smoke was def burning oil. your hp #s are low for that amount of boost so it still is decent for the problems your having. how long did u have the setup running well ?
Old Oct 10, 2004 | 11:08 AM
Ri5e's Avatar
Welps, it's time for a rebuild!
Old Oct 10, 2004 | 12:55 PM
GReddy SI's Avatar
Default Re: well just as i thought ... (TurboSmart)
yup already ordered Wiseco Pistons w/ Rings, Eagle Forged Rods, acl bearings
took my block to get rehorn and hot tanked.
hopefully i can get it up and running this week coming up
Old Oct 10, 2004 | 12:58 PM
Boosted Chemist's Avatar
at least its not as fucked as my friends d16z6 #4 ran lean due to a bad injector (NA motor) and killed the bearing and hit the bottom of hte sleave. When we pulled the rod there was no bearings left at all
Old Oct 10, 2004 | 12:59 PM
the_0ne's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GReddy SI &raquo;</TD></TR><TR><TD CLASS="quote">yup already ordered Wiseco Pistons w/ Rings, Eagle Forged Rods, acl bearings
nice, good luck with it!
Old Oct 10, 2004 | 09:31 PM
GReddy SI's Avatar
Default Re: well just as i thought ... (the_0ne)
tarheelsoldier
Jan 30, 2007 06:25 AM
boosted ek
Apr 24, 2005 06:10 PM
20lbbooster
Feb 7, 2004 10:06 AM
Sonny
Aug 23, 2002 08:06 PM
