Is my oil return line safe?
that kink is not good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude »</TD></TR><TR><TD CLASS="quote">i'd get a 45 deg. fitting off the oil pan</TD></TR></TABLE>
Lowe's or Homedepot...fab one up and post again!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM »</TD></TR><TR><TD CLASS="quote">ya dood , a 45 off the pan would fix that perfectly</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch »</TD></TR><TR><TD CLASS="quote">i'd use those parts and weld the bung on crooked. seriously, i probably would because it would fit better than a 45</TD></TR></TABLE>
i agree
i agree
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 »</TD></TR><TR><TD CLASS="quote">I dont think a 45 would work, it would just make the angle even worse. I'd try a 90 off the pan.</TD></TR></TABLE>
Thats what I figured...i'll probably try a 90 next
a 90 will impede flow. Go with a 45 if possible
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost psycho »</TD></TR><TR><TD CLASS="quote">
a 90 will impede flow</TD></TR></TABLE>
Not as much as the kink thats in there now!
should use a 45 and clock the center section of the turbo towards the frount of the car alittle bit... but yeah I would get the kink out of that or bye bye turbo
Looks like he can clock the center section just a lil bit, or else it'll be in the way of the downpipe. A 45 would definitely help. You could also try giving the steel bung on the oil pan some taps upwards. The oil pan will give a little.
and don't use vice grips, it looks like your ate some of the fitting. Go to Sears and get a 1" Standard open ended wrench (or it could be 15/16")
Fred
Fred
