No difference between 8lbs and 14lbs boost!
Old Oct 12, 2004 | 10:36 AM
turboman's Avatar
Default No difference between 8lbs and 14lbs boost!
OK I think I'm probably gonna answer my own question but thought I would post it here to confirm.
I was playing with the car up in the mountains yesterday. Started changing the boost up and down between 7 to 14. Honestly didn't notice any difference in power.
My guess is I really need to change the exhaust and downpipe(rather tiny). I haven't had the head ported so that might be the problem also?
Old Oct 12, 2004 | 10:41 AM
RyanEJ8's Avatar
Default Re: No difference between 8lbs and 14lbs boost! (turboman)
Sounds like there is something more wrong if you don't feel a difference between 8 and 14 psi.
Old Oct 12, 2004 | 10:45 AM
ATS*Mark's Avatar
OG triple OG
Default Re: No difference between 8lbs and 14lbs boost! (RyanCivic2000)
is the car tuned for 14 psi? if your tuned for 7psi raising your boost will just cause you to go lean.......
Old Oct 12, 2004 | 11:21 AM
Pfieff's Avatar
check for some exhuast leaks or places were you would lose pressure
Old Oct 12, 2004 | 11:51 AM
MidShipCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboman &raquo;</TD></TR><TR><TD CLASS="quote">
I was playing with the car up in the <FONT COLOR="red"> mountains yesterday </FONT>. Started changing the boost up and down between 7 to 14. Honestly didn't notice any difference in power.
Did you add more air to that fuel?
Modified by MidShipCivic at 1:29 PM 10/12/2004
Old Oct 12, 2004 | 12:12 PM
turboman's Avatar
Default Re: No difference between 8lbs and 14lbs boost! (MidShipCivic)
Cars runs sorta rich but not to bad. It's tuned to run up to 20lbs but I have never tried it. As far as I know the hondata knew how to add the right amount of fuel no matter what the boost was at.
racin jasin R
Jun 24, 2007 11:08 PM
teddy_dc2
Aug 6, 2006 07:10 AM
honkey2fly
May 26, 2004 11:56 AM
93TurboSi
Oct 16, 2003 06:04 PM
LOwrestling2001
Sep 4, 2002 10:54 AM
