Wastegate rubbing
Old Oct 13, 2004 | 11:28 PM
Project99EK's Avatar
Default Wastegate rubbing
anyone else having this problem? i have a 94 hatch with a gsr swap with a t3/t4 turbo right now im running the drag turbo mani and a tial 38mm wg bascially underboost it looks like or whnever its rubbing against the hood and its rubbing away enough that u can see that a layer of it si just gne making my tial look ugly =p any one else have this problem and what did u do? sooner or later its gonna just rub all the metal off the top and then ill just have a big hole
Old Oct 13, 2004 | 11:33 PM
Adi Radoncic's Avatar
On Fire!
Default Re: Wastegate rubbing (Project99EK)
2 fixes to this problem, you can build yourself a wastegate elbow using 3 35mm flanges and a 90deg pipe, or you can see where the wastegate is rubbing on the hood and hope that its on the skeleton or the supports on the hood. If this is the case just cut a pace of the metal off where its rubbing at and your good to go.
Old Oct 14, 2004 | 08:48 AM
Default Re: Wastegate rubbing (newgsr)
thanks for the help its wierd its bascially half and half cause the hood is like burnt on the skeleton half and off it as well =p
LSej1
Apr 22, 2010 05:35 AM
BobGnarly
Aug 9, 2004 11:13 AM
flarinpnoi
Apr 28, 2004 09:41 AM
Nextelbuddy
Mar 26, 2004 01:26 PM
BoostedGSRBubble
Mar 5, 2003 07:45 PM
