headgasket question????
Old Oct 11, 2004 | 09:04 AM
Big Josh's Avatar
Default headgasket question????
i gotta replace my head gastket on my car.......im running a 81.5 bore.....the last headgasket i used was a stock gsr one(81mm..correct me if im wrong).........
is this not good to use the stock bore gasket...if im running just a little bigger bore.....im wondering if that could have been the problem i ran into with the old one........
if i do need a special headgasket for that bore....can someone please guide me in the right direction as far as company or maybe online shop
all feedback will greatly appreciated
Old Oct 11, 2004 | 09:08 AM
m R g S r's Avatar
Default Re: headgasket question???? (Big Josh)
You can buy overbored OEM headgaskets from Race Engineering or Golden Eagle. .
Old Oct 11, 2004 | 09:10 AM
Big Josh's Avatar
do you have any idea of the cost........or if that is a big deal for 20 over
Old Oct 11, 2004 | 09:17 AM
TwoPointZero's Avatar
Banned
Default Re: (Big Josh)
Get your head milled just a little. Get a 20over headgasket and put it back on. Im pretty sure that was your problem. If you don't got ARP headbolts.. i suggest you get those too. Goodluck.
Old Oct 11, 2004 | 09:23 AM
Big Josh's Avatar
why do you suggest getting my head milled i would think that would raise the compression?.......i already got the arp headbolts...so i should be good there.....
Old Oct 11, 2004 | 09:30 AM
Banned
Milled just incase it warped. If milled just mill it a little. It will flatten the surface and not higher your compression. Only way to higher compression is if you mill it like .020
Old Oct 11, 2004 | 09:36 AM
Big Josh's Avatar
oh ok.........well i really don't think its warp.....its not like a really bad headgasket problem such as leaking down the block or nothing.....is buring some coolent and i seen some oil in my radiator.
Old Oct 11, 2004 | 09:45 AM
Banned
It only costs $25 to mill.. better safe then sorry.
Old Oct 11, 2004 | 09:48 AM
X-Mazda 3 Racer's Avatar
Default Re: (TwoPointZero)
The stock gasket was designed to handle from the stock 81 mm bore up to 81.5 mm . A stock gasket would be fine for your application. If you need, we have them in stock and ready to ship. Check out our online store at http://www.goldeneaglemfg.com Hope this helps.
Vince
Old Oct 11, 2004 | 09:56 AM
Big Josh's Avatar
thank for all the help
got00rice
Nov 16, 2009 11:22 AM
ek_kid
Mar 22, 2006 09:47 PM
4th gen civic racer
Jan 19, 2005 04:28 PM
CalvitoSol
Apr 11, 2003 02:11 AM
crxONcrack
Mar 17, 2003 08:36 AM
