oil between DP and turbo
Old Oct 11, 2004 | 10:54 AM
slo_crx's Avatar
Default oil between DP and turbo
ok well i guess i blew my seals on my turbo but im not sure and i want all of ya''lls input ..ok well i know i fukked up cuz my oil return line makes an S shape and thats no good ..but i was wondering if my turbo went bad because of that and it had too much pressure in teh turbo because it couldnt get all the oil out ...and i was also wondering if i where to fix my oil return line would the turbo be ok ..or do i still need to rebuild it and how much would that be?
Old Oct 11, 2004 | 12:46 PM
slo_crx's Avatar
Default Re: oil between DP and turbo (slo_crx)
come n people ... is my turbo blown?
Old Oct 11, 2004 | 01:18 PM
FmXRider991's Avatar
check to see if your oil return line hose is leaking
Old Oct 11, 2004 | 01:49 PM
Street Ghost's Avatar
Default Re: oil between DP and turbo (FmXRider991)
Try running a different Oil Return setup and see if it helps any. If not, you may need to rebuild or buy another turbo.
Old Oct 11, 2004 | 02:11 PM
slo_crx's Avatar
Default Re: oil between DP and turbo (_Project EJOne)
ok well i KNOW the cause is the oil return line the turbo is almost brand new .. but what im saying is if i fix the return line will the turbo be ok ??
Old Oct 11, 2004 | 03:37 PM
smk99ebpsi's Avatar
Is it smoking out the exhaust?
Old Oct 11, 2004 | 03:41 PM
Ace.'s Avatar
Default Re: oil between DP and turbo (smk99ebpsi)
Definetly check your oil return flange seal, as well as the fitting seal...also check your feed line connections as well...
Old Oct 11, 2004 | 04:20 PM
slo_crx's Avatar
Default Re: oil between DP and turbo (AceAltima)
nope its not smoking out the exhaust ...also what do i look for to see when i check the seals??
Old Oct 12, 2004 | 05:51 PM
slo_crx's Avatar
anyone know if my turbo could still be good?
CivicDude2k4
Sep 5, 2006 08:24 PM
dturbo
Apr 5, 2005 03:44 PM
Blkteg97
Nov 16, 2004 08:04 AM
jacob_kohler
Sep 17, 2004 12:44 PM
Elite Hatch
Oct 20, 2002 05:43 AM
