which fmu for d16z6
Old Oct 9, 2004 | 05:48 PM
Mr.Death's Avatar
Default which fmu for d16z6
I have a d16z6, ihi rhb5 turbo(8lbs boost) hf mani and dsm side mount intercooler. What size fmu is required for this setup and will I need new injecters and fuel pump?? Thanxxx.
Old Oct 9, 2004 | 05:56 PM
sleeping GIANT's Avatar
Default Re: which fmu for d16z6 (Mr.Death)
I cant say that any fmu would be your best bet as far as fuel managment but Ive put a 12:1 vortech on a z6 w/ a 14b turbo running 9lbs. of boost. you do not use bigger injectors with the fmu, though putting a walbro 190, or 255lph fuel pump in would be your best bet when using the fmu. the fmu will make your car run extremely rich . hope that helps. BTW you will also need a missing link to hide the boost press. from the ecu!!!!!
Old Oct 9, 2004 | 06:29 PM
Tad's Avatar
Tad
Default Re: which fmu for d16z6 (sleeping GIANT)
fmu's are really unreliable,
there I said it,
i'm sure you'll get enough people covering the fact that you shouldnt run an fmu, but rather uberdata or vafc hack
BUT if you do go the fmu route,
you definetley must get a fuel pump,
walbra intank is a good choice.
you dont need upgraded injectors, that will only eff up your idle.
10:1 or 12:1 are your choices, most ppl go with the 12:1 but I think its overkill,
you can run rich as **** with your 12:1 fmu and still be just as unreliable, cuz those thinks can konk out on you at random, and they're completely untuneable.
if it was me i'd run a 10:1, especially for 8lbs.
edit: thats 4000posts for me
EJ8 GSR-T
Aug 23, 2005 07:49 PM
Boostless97Lude
Nov 3, 2002 11:34 PM
TurbothisLS
Sep 22, 2002 07:22 AM
RTW DC2R
Jun 5, 2002 07:41 AM
4gvtec
May 19, 2002 09:18 AM
